Sony KDL-40SL140 way too bright
  • billydanger
    • Feb 2014
    • 15
    Ok, stay with me:
    1. originally had solarized picture and so I replaced the TCON board.
    2. After replacement I got nothing but a blank screen. Backlight was on but that was all.
    3. after much searching and probing I found an open fuse on the mainboard that I must have popped somehow.
    4. Replaced fuse and all functionality returned EXCEPT the screen is now really bright. Not like I have a supercharged backlight but more like the brightness is turned all the way up (which it isn't). Picture is not solarized like before TCON replacement, just too bright.
    Eventually (10-15 minutes) screen will fade back down to near-normal brightness level and then return to high brightness after a few more minutes. Process repeats until I get sick of looking at it.
    The mainboard fuse was F4001 (24V, 5A) and is in-line with IC number Q4018 (UPA1716G-E2). The schematic is shown in service manual page 44.
    Thoughts?
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Sony KDL-40SL140 way too bright
    Adjusting the Contrast and Brightness did not help?....There might be a Backlight adjustment in the Main Menu. too....Turn them down.
    • billydanger
      • Feb 2014
      • 15
      Adjusting the usual options doesn't seem to help much. I can get it close to something resembling a decent picture but it just returns to the "super bright" display after a few minutes.
      Also, I wiggled cables and TCON ribbon cables, as well as used a heat gun around the edge of the screen to look for bonding issues but I was never able to find anything.
      • billydanger
        • Feb 2014
        • 15
        I tried to take a little video with my phone but naturally the TV is playing just fine right now. Maybe later...
        • billydanger
          • Feb 2014
          • 15
          I replaced the AS15 chip on the "new" TCON board that I bought and that seems to have done the trick. Colors are still a little bit off but I think that can be fixed with proper adjustments.
          So. Fixed. Bad TCON board as was the original diagnosis.
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Disappointing that you had to repair the replacement Tcon but looks as though you've nailed it. Well done
            • Hamie
              • Apr 2014
              • 1383
              You may still have an issue with the gamma chip. Maybe one leg not quite soldered properly.
              Many people including myself have had issues with brand new chips being faulty straight out the box.
              Check your gamma voltages.
              • corrize
                Replacing resistor fuse in Sony DV charger
                by corrize
                Hello, I have 2 old chargers for Sony DV, and I found the same resistor fuse dead. Fuse is a crossing component : 0,47 Ohms (0,125W deduced because the lenght is 3mm). But I can’t find the same for buy.
                So, I want to replace by another like 0 Ohms, 1 Ohms 0,125W,
                It is the same please ? I guess it’s the same, the only change should be the time to burn ? Thanks...
                06-30-2025, 06:59 PM
              • corrize
                A funny fuse story – Lumix LX100 II
                by corrize
                Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                10-19-2023, 09:58 AM
              • Carlos#2003%
                Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                by Carlos#2003%
                Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                02-15-2024, 07:52 PM
              • dkneyle
                Sony KDL-46HX850 Can't upgrade/update firmware
                by dkneyle
                Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                09-25-2024, 10:44 PM
              • jesterace
                Samsung UE46ES8000 Blown fuse but no other signs of short
                by jesterace
                Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                09-11-2024, 03:14 PM
