Lenovo G570 Audio not working
  • borbooroski
    • Mar 2014
    • 177
    • Ghana
    Hello brothers Igreet you all please there is this Lenovo G570 which can't install audio drivers pleasekkindly help if you have any idea this the board below
    ..Thanksa lot..
  • Diah
    • Feb 2013
    • 6594
    Re: Lenovo G570 Audio not working
    beside the power round key. you have small pin on the surface press it while turn on to inter the BIOS check there the audio listed and active ?
    • borbooroski
      • Mar 2014
      • 177
      • Ghana
      please i need help please
      • borbooroski
        • Mar 2014
        • 177
        • Ghana
        ..Thanksa lot..
        • samson7point1@yahoo.com
          Help troubleshooting an audio problem with an RCA SGT-250 CED Player
          by samson7point1@yahoo.com
          The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
          The player processes the audio signal using two different reference frequencies. The "R"...
          04-30-2024, 11:22 AM
        • coasterghost
          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
          by coasterghost
          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
          System Hardware:
          Processor: AMD Ryzen 7 PRO 5850U
          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
          09-08-2025, 10:46 PM
        • hopkok
          Lenovo Legion 16ITHg6 NM-D721, keyboard not working, LEDs too
          by hopkok
          Hi masters, I need your help.
          I am working on Lenovo Legion 16ITHg6
          Motherboard number NM-D721, no BV, no schematic but I am attaching very closes ones.
          INPORTANT: My motherboard version is with IT8258 IC, that is controlling keyboard and RGB LEDs.
          My problem is on UI142, +3VALW_AG is not stable, floating from 0V to 3,3V.
          AGKB_PWR_EN_N signal is floating too (that is why+3VALW_AG not stable).
          Power LED is not working as well, power button working well.
          UI26 ??? is there any firmware too? Powered by +3VALW_AG.
          Motherboard...
          05-04-2025, 09:35 AM
        • someonenotyou
          Lenovo A485/T480 USB stops working when USB2.0 is plugged.
          by someonenotyou
          Hi.
          I have 2 Lenovo laptops (A485 and T480) with identical USB problem.
          When I plug in a USB 3.x device (USB storage), the USB ports are working normal.
          But as soon I plug in USB 2.0 device (mouse, USB storage), all the USB ports stop working. Even if I plug in USB 3.x device.
          The only way to get USB working again is disconnect battery and reset BIOS.
          Has anyone had anything similar?
          I have not yet tried another BIOS, but would that be the problem with USB?
          Thank you.
          03-19-2025, 12:15 PM
          Lenovo Yoga 730 Hybrid (2-in-1) 700 Specification for Upgrade or Repair
          This specification for the Lenovo Yoga 730 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 730 boardview and 730 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo Yoga 730...
          09-06-2024, 08:27 AM
