60PB5600 no picture
  • Srtech
    • Jan 2017
    • 19
    60PB5600 no picture
    I am just learning about Plasma and LCD/LED TV's and have an LG 60PB5600 that turns on but no picture or menu. It does power up with a white screen flash. The blue indicator light on the front of the set flashes when I press the menu button, but no menu appears on the screen.
    The vs and va voltages are according to the label as are all voltages on the connector to the main board. (RL_on =3v)
    After reading other posts, I tried getting the test patterns but no success. I jumpered EXT_AUTO_GEN, unplugged the blue ribbon from the main board, unplugged P231 from the main board and jumpered RL_on to 5.2v. Then plugged the set in and turned it on, but all I got was flashing green LED on the control board.
    At first it was three short and one long pattern. Now it is four long flashes.
    Where do I go from here? Thanks for sharing your knowledge.
  • Hamie
    • Apr 2014
    • 1383
    Re: 60PB5600 no picture
    Pictures of the boards?
    Need to check vsc and Vy test points on the ysus.
    • Srtech
      • Jan 2017
      • 19
      Ok so here are a set of pictures.
      Measurements are vsc on P152 is at 235.7 vdc, and vy on the test point is 85.4 vdc.
      • Srtech
        • Jan 2017
        • 19
        Ok, so after looking at the other messages on this tv, I did more checking.
        Voltages on y-sus board at P152 connector are:
        Vpp = 235.2v
        Vsc = 235.2v
        5vf = 90v
        Sus_on = 85v
        On P151 at pin 7 there is "15vf" = 100v
        Va on the power supply = 54.7v and the same on the z-sus board.
        I checked the four igbts Q401, Q404, Q405 and Q406 and none are shorted but test as diodes.
        So should I be looking at a Main Board? I have white screen flashes at power up, and sound is working, just no picture or menus.
        • Srtech
          • Jan 2017
          • 19
          In addition Imchecked the following voltages at the power supply connector P813
          M_on = 3.06v
          RL_on = 3.1v
          5.2 = 5.2v
          17 = 17v
          AC_on = 5v
          17v_det = 2.5v
          VS_on = 3.07v
          vs_det = 2.5v
          • Hamie
            • Apr 2014
            • 1383
            Remove buffer and recheck vy and vsc.
            • Srtech
              • Jan 2017
              • 19
              I am not sure where vy is accessible as I don't see a clear identification on the y-sus board.
              However at GR 170 = 84.7v
              And at GR250 = 271v, since they are marked as vy - and vy+ respectively, I assume vy is the difference of 187v. It is the same with the buffer disconnected.
              With buffer connected vsc = 235.3v measured at P152, but with the buffer disconnected vsc = 0v at P152.
              • Hamie
                • Apr 2014
                • 1383
                No
                black probe to -
                Red probe to +
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Originally posted by Hamie
                  No
                  black probe to -
                  Red probe to +
                  Good patients bud lol
                  • Srtech
                    • Jan 2017
                    • 19
                    Ok the vy voltage reads 187v DC and is the same with both buffers disconnected.
                    • Srtech
                      • Jan 2017
                      • 19
                      Like this?
                      • Hamie
                        • Apr 2014
                        • 1383
                        Edit:
                        OK y-sus is probably OK.
                        When you first turn on the tv do you get a brief flash of the screen? Or does it always remain pitch black?
                        • Hamie
                          • Apr 2014
                          • 1383
                          Do you see where the top buffer connects to the bottom buffer. (white flat cable)
                          There are some smd capacitors, can you tell if any are shorted?
                          • Srtech
                            • Jan 2017
                            • 19
                            Yes I get the flash (prime as I have learned)
                            • Srtech
                              • Jan 2017
                              • 19
                              Yes I see three caps and measure two at 0.01uf (shorted I assume) and one at 35uf. One is blown apart also!
                              • Hamie
                                • Apr 2014
                                • 1383
                                No probs, check those smd caps, that may be your only problem and you can fix this for practically nothing.
                                • Hamie
                                  • Apr 2014
                                  • 1383
                                  Too quick for me.
                                  No for this test put your meter in ohm.
                                  See if they are low resistance.
                                  I'm pretty sure the top one should be 4uf.
                                  Can't remember though I'll need to check.
                                  • Srtech
                                    • Jan 2017
                                    • 19
                                    Sounds good Hamie, thanks for spending some of your evening on this. What values should those smd caps be?
                                    • Srtech
                                      • Jan 2017
                                      • 19
                                      So for resistance two are open (C873 & C975) and C956 measures 5k.
                                      C873 is broken also.
                                      • Hamie
                                        • Apr 2014
                                        • 1383
                                        Yeah I though it was just your photography that c873 is actually split in 2!
                                        The other 2 are probably OK.
                                        OK so change it out, give me few minutes I need to get the exact value.
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
                                        • Rauni
                                          Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
                                          by Rauni
                                          Hello, this is my first post on this forum, and my first attempted to repair a TV.
                                          My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
                                          Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
                                          Read also that we should test what happens if we...
                                          10-01-2023, 12:06 AM
                                        • Retro140
                                          Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
                                          by Retro140
                                          So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
                                          To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button...
                                          06-18-2023, 06:13 PM
                                        • Dobsuk
                                          Samsung UE50TU8000K no picture or lanes on it
                                          by Dobsuk
                                          Hi guys, i am dealing with one Samsung 50TU8000K which was without picture - just was resetting itself constantly. Saw some videos and read some post about simmilar issue and the advise was to try to tape cut off method and started to put tape on some of the pins on this ribbon cable:
                                          And then i had picture but with lanes. Tried different pins and combination but could not managed to make it work without any lanes so far. Will keep playing with it though.
                                          The weird thing is that i tried it again without any tape on the pins and now i have picture with just few lanes...
                                          04-25-2023, 07:34 AM
