Sharp Aquos LC-70LE650U display is slow and discolored
  • wilbanks951
    • Jan 2017
    • 22
    Re: Sharp Aquos LC-70LE650U display is slow and discolored
    I'll make sure to post an update in the future.
    • capwizard
      • Jun 2016
      • 1991
      wilbanks951 : Waiting for your update!
      My Sharp 60 TV customer never returns it for about 3 months.
      Is castrated-one-side-TABs-TV will be the same as before?
      But ..but.... pero...I think, Every other horizontal lines are disappeared (At 1080P) but TV may be use interlace so we not notice it.
      Can someone use high power magnifier glass double check it? Something wrong down there but look is A OK?
      • sefoster
        Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
        by sefoster
        I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
        11-20-2022, 09:29 AM
      • jonah1024
        Sharp Aquos LC-40UG7252E LCD TV burn in?
        by jonah1024
        Hello!
        I'm a few days old into this TV screens repair universe so please bear with me.
        Recently, and all of a sudden my 40” 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
        - I did the classic unplug and hold power button to discharge the caps but it didn't help.
        - I did a factory reset as well...
        07-16-2024, 04:23 AM
      • joblo37pam
        Sharp LC-80LE844U Blinks 2 slow, 5 fast
        by joblo37pam
        It's been a while since I've checked in here or needed input on narrowing down what to replace on a TV repair, but I've got one on my bench now that has me wondering. The lack of part (board) availability means I may need to do some component-level diagnostics, and a second opinion is always good when it comes to that.
        The issue - Sharp LC-80LE844U does not display. Power light comes on for a while, then you can hear a relay click off and the light blinks twice slow, then five times fast. Service manual points to 'Panel Power Supply Error' with this code, but isn't much more help...
        10-26-2023, 02:17 PM
      • klassic
        Sharp Aquos LC-60LE635E three blinks
        by klassic
        Hi community,
        I will describe my problem with a TV in those short following terms to be the most precise :
        What i have :
        power board DPS-162KP-1
        main logic board QPWBXF733WJN2
        symptoms :
        white led light logo at startup,
        after 2 minutes, blinking 3 times a row, repeating
        no backlight (and apparently no picture, checked panel with flashlight)
        no startup sound
        powerboard investigations :
        1-2 PNL : 0v
        3-4 GND
        5-6-7-8 UR : 13.15v
        9-10-11-12...
        10-24-2023, 01:39 PM
      • foxyUK
        Sharp Aquos LC-32LE600E, No 12v as no PNL_POW
        by foxyUK
        Can anyone help me diagnose this? Almost not worth bothering with, but it has 'sentimental value' for the owner. I'm no TV technician, but dabble a bit.
        The TV has standby power but no reaction at all to switching on or reboot steps, No flashing lights or response to menu button. All voltages on the power board are correct apart from missing voltage on pin 12 of CN7003.
        There is 13 v on U7053 but no 3v signal to switch it on. I don't really understand whether the 3v should come from U7401 in the standby control area, or (as suggested elsewhere) from the mainboard via pin 12....
        10-22-2024, 10:27 AM
