samsung PS51D550
  • jmh474
    • Aug 2016
    • 46
    samsung PS51D550
    ok to i have a samsung PS51D550 plasma tv, it came to me not powering up and just clicking so i thought easy fix caps on main board.... i was wrong now iv come to find that its the xsus board.
    sounds good so far still easy fix, this is where my problem is finding the right xsus board, i buy most of my parts on ebay uk (unless you know better please tell me), my problem is i type in the PCB No LJ41-09422A and it brings up different types of the same board,
    part 1
    http://www.ebay.co.uk/itm/LJ41-09422...UAAOSwLF1X6BeB
    part 2
    http://www.ebay.co.uk/itm/LJ41-09422...8AAOSwMVdYHJ4f
    there is a £20 difference may not be alot to some people but it is to me, this is the board i need any help would be grate
  • jmh474
    • Aug 2016
    • 46
    Re: samsung PS51D550
    if im right and the numbers do matter i think iv found the right one
    http://www.ebay.co.uk/itm/Samsung-Xs...QAAOSwA3dYVDFr
    • jwheff
      • Apr 2017
      How'd you go with your one using that part?
      My TV has been sitting in the garage for about a year and I'm just getting around to searching for parts again.
      From memory had no power at all, just bought a main PS board and it now has power. But clicks then has a 5 x 2 red blinking light.
      I'd like to be able to attempt repairs myself but don't have much experience, so I think I'll be looking to source both the Y and X boards to see if I can get it going again.
      • StephenU
        • Dec 2013
        • 230
        • United Kingdom
        @jmh474
        Pretty sure I have one of these TV's in at the moment, panel was damaged, if you haven't purchased already I can double check tonight and let you know?
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • ohren
          by ohren
          09-08-2023, 05:24 PM
        • C152Heavy
          by C152Heavy
          Summary for TL-DR readers:
          • VCC pin (18) of PFC...
          01-11-2023, 02:53 PM
          09-07-2024, 05:50 AM
