Vizio E371vl--Decline to failure (diagnosis?)
  • ivtec
    • Dec 2008
    • 1967
    Re: Vizio E371vl--Decline to failure (diagnosis?)
    Originally posted by DoorOfTime
    Finally got a chance to freeze the chips. The TV had been unplugged for ~2 days so it was functional when I turned it on.
    Worth noting--the computer I used to connect to HDMI detected the TV as an output whether or not the TV was turned on.
    While displaying HDMI on the screen I froze the EEPROM--no apparent change. Shortly after I started chilling the main chip the image cut out, the computer lost the HDMI output, and the TV powered down.
    So, it looks like this is a main chip problem. I don't have the equipment to reflow at my apartment, and the only thing I can get my hands on is a heat gun which is a bit barbaric.
    It seems odd to me that the chip would have errors both when it has been on for an extended period or when it is chilled. What exactly would be causing that problem?
    Hi DoorOfTime; It not barbaric cause i have a M42vt led tv that had a scrambled pic this tv i found on the curve too, i did the heat gun reflow on the BGA and tv has been running like a champ for a year now,also put a fan on the back of the BGA,just try to reflow with the heat gun just like this Utube video shows,if you do that way it will not harm the board.
    https://www.youtube.com/watch?v=J5fzUrP0pxs
    • howardc64
      Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
      by howardc64
      Problem
      Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
      Model & Board Pics
      Conflicting Spec
      Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
      https://www.shopjimmy.com/vizio-gj-2k1...
      10-10-2024, 01:16 PM
    • coasterghost
      Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
      by coasterghost
      For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
      Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
      Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
      System Hardware:
      Processor: AMD Ryzen 7 PRO 5850U
      Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
      09-08-2025, 10:46 PM
    • ipatch
      ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
      by ipatch
      i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
      08-24-2024, 02:36 PM
    • bstewara
      Vizio P659-G1 Screen Removal / Backlight Replacement
      by bstewara
      Hi All,
      Has anyone had the experience of replacing backights on the “P” series Vizio tv?
      Model number P659-G1
      This type tv has a very small bezel holding the screen in and I’m not sure how the bezel/screen is assembled. ( I’m hoping the screen is not epoxied to the frame)
      Before I attempt this I thought maybe someone on this forum has performed this backlight replacement procedure.
      Thanks in advance...
      09-26-2022, 10:40 AM
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
