LG Blank screen
  • andrews7523
    • Apr 2015
    • 117
    • lancashire
    LG Blank screen
    Hi i have a Lg 55uh661v with a black screen. Ive tried removing each tab which goes to the screen as it doesn't have a Tcon. Ive been told this can be fixed is that right? I know I've had a main board cause this fault but only as it was the incorrect one fitted by the factory
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: LG Blank screen
    Removing the TABs was not a good idea. To replace them you would need a Tab Bonding Machine......Maybe those who told you it was easy to fix have the skill and precision machinery to re-bond TABs to the screen. An incorrect Main Bd fitted at the factory......hardly likely yet possible......Then there would have been a recall of that Brand and Model.....I haven't heard of any.....
    • andrews7523
      • Apr 2015
      • 117
      • lancashire
      Re: LG Blank screen
      I meant the ribbons from the mainboard not the actual tabs on the screen
      • dskall
        • Oct 2016
        • 2905
        • usa
        Re: LG Blank screen
        Do you have backlights, sound?
        • andrews7523
          • Apr 2015
          • 117
          • lancashire
          Re: LG Blank screen
          It has backlights. Ive not plugged anything into it but i dont think theres any sound
            Re: LG Blank screen
            Can we at least see the pictures of the whole back side of the TV showing all the boards so we can see what we are dealing with?
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
            • Chrissygizmo
              Panasonic TX-48CX350B backlights but white screen , blank screen
              by Chrissygizmo
              Hi all, I’ve got a problem I hope someone can help me fixi.
              I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
              01-11-2025, 03:18 PM
            • kotel studios
              Funai 32FL553P/10 - squealing from PSU, dies after 10 seconds, blank screen after logo, bootloops
              by kotel studios
              Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
              State I got it in:
              Squealing from the PSU
              After logo I get a blank screen
              After 10 seconds of having a blank display w/ backlight the TV dies
              Give it 7-10ish seconds again and it starts to bootloop.
              What I did so far:
              Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
              Checked all voltage rails:
              5VSB - 4.8V
              AMP+13V - 14.4V
              13V - 12.98V (in manual 12V)...
              09-21-2025, 02:00 AM
            • reformatt
              by reformatt
              07-31-2025, 08:37 PM
            • Kalman27
              Lenovo IdeaPad Slim 5 14IAH8 - Type 83BF OLED Blank screen
              by Kalman27
              We have a Lenovo IdeaPad Slim 5 14IAH8 - Type 83BF for repair. The original issue the OLED screen is blank.
              We have replaced the OLED screen with the exact model, also we replaced the LCD cable, but no luck.
              I think there is something with the motherboard. I don't really have experience with OLED screens so far, so not sure how it should work. I have seen some laptop comes with a separate controller board, but this model does not.
              Also, there is an error in Windows device manager - This device cannot start (Code 10) - Intel(R) Serial IO I2C Host Controller...
              06-17-2025, 05:52 AM
