Samsung Plasma TV model PN64F8500 power on issue
  • BK24
    • Jul 2019
    • 6
    Re: Samsung Plasma TV model PN64F8500 power on issue
    Also, I found a couple 22uf, 50V aluminum electrolytic capacitors on Mouser -
    EEU-FR1H220B & EEU-FR1H220
    but I don't know if either is/would be the correct replacement?
    • jetadm123
      • 2169
      without knowing the differences between the 22uf and 30uf y board versions, I would stick with the 22uf. Is there just the single 22uf cap with two empty spaces next to it? You can use a ceramic 22uf 50v cap similar to:
      https://www.digikey.com/product-deta...958-ND/7362914
      • BK24
        • Jul 2019
        • 6
        No, it's a cylindrical shaped cap. I'll try to attach a pic.
        The space right below it is where the 3 caps are on most of the (older?) boards.
        But if the cap in the link you sent will work, I will try it for sure.
        Also - thanks for your help, jetadm123!
        • jetadm123
          • 2169
          Thanks for the photo. Would be interesting to know if you have a newer or older version of the Y board as compared to the others in this thread. Yes, the EEU-FR1H220B & EEU-FR1H220 will work fine. Just be aware that the capacitor has a "+" and "-" and must be installed the same way as the old cap.
          • BK24
            • Jul 2019
            • 6
            I'm not sure. I can take a pic of my board specs when I get home, but I don't have that on hand.
            Is the type of cap I sent better, or the ceramic type you sent better? Does it matter?
            • jetadm123
              • 2169
              #26
              The board you have uses a electrolytic cap versus ceramic for the other boards. I would go ahead and use panasonic ones you chose.
              • BK24
                • Jul 2019
                • 6
                Great! I'll order a handful of those Panasonic caps. Wish me luck. Haha
                Thanks again for your time, jetadm123.
                • budzcars
                  Budzcars
                  • Mar 2014
                  Hi I hope some one is still following this as I am looking for some help
                  I have inherited a Samsung PN64F8500AFXZA (that someone else couldn't fix} that wont turn on I am getting 2 red blinking flashes , I have tested power supply tests ok by using methods in this forum , It looks like somebody replaced the 3 blue caps on y board but I unplugged ribbon on Y and I am not getting any vs voltage , where on board should I be checking right now I am on pin 13 of top white plug is this correct spot ?
                  • Kjell
                    Samsung Series 9 - BIOS issue
                    by Kjell
                    After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                    Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                    08-01-2025, 09:15 AM
                    09-07-2024, 05:50 AM
                  • lp20th
                    Samsung Plasma TV Power Supply Issue
                    by lp20th
                    I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
                    11-28-2023, 10:28 AM
                  • Nairolf
                    Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                    by Nairolf
                    I have a Samsung DM32D display.
                    When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                    Here’s what I have tried so far:
                    1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                    2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                    3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                    From these tests, I suspect the problem might be on the mainboard. Could anyone...
                    08-24-2025, 03:47 AM
                  • vincentedel
                    Samsung SyncMaster 740n Phase Control Issue
                    by vincentedel
                    I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                    I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                    04-22-2025, 12:33 AM
