Samsung PN60F5500, making me question my sanity
  • Truncatedhose
    • Oct 2014
    • 343
    Re: Samsung PN60F5500, making me question my sanity
    Okay, so there is no glow from the screen, but what do you mean by the LVDS cable? Do plasmas even have and LVDS? I thought only LCD/LED use these. f you're talking about a cable from the main board, which cable are you talking about specifically?
    Also, to mtnickel, this TV doesn't have a separate logic board.
    • rccrasher65
      • Mar 2014
      • 622
      Yes plasma's have an LVDS, go back to post 16 Tom66 explains all you need to do with a Samsung plasma Tv, click on the link he left, it will show you step by step what to do.
      • Hamie
        • Apr 2014
        • 1383
        This model doesn't have an lvds cable.
        • mmartell
          • Oct 2013
          • 3189
          Signal remains at board level with presumably much shorter travel distance so LVDS is not necessary. Even if it is it's integrated to the board circuit itself.
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            #45
            maybe time to try a replacement mainboard? have you swopped any other boards?
            • Truncatedhose
              • Oct 2014
              • 343
              Thanks for all the support, guys.
              Hamie, there is no glow; checked in a dark room. I will try the BGA pressure once I confirm things below.
              rccrasher65, what do you mean by the LVDS cable? I wasn't aware plasmas had one? Can you indicate what cable you mean specifically?
              mtnickel, this model doesn't have a separate logic board. I could pull the X and Y again and check for shorted fets, but wouldn't there be a blown fuse if that was the case?
              • Hamie
                • Apr 2014
                • 1383
                OK so this is the control board section of the mainboard.
                • Hamie
                  • Apr 2014
                  • 1383
                  This looks like the LED for the control board.
                  Does it blink? Either with the power supply jumpers in place or if you remove jumpers and plug back in mainboard?
                  If this led doesn't blink I'd seriously consider replacing the mainboard.
                  • rccrasher65
                    • Mar 2014
                    • 622
                    As Hamie stated your model does not have an LVDS cable. That was my fault for not reading entire thread. +1 for looking for new main board.
                    • Truncatedhose
                      • Oct 2014
                      • 343
                      It doesn't blink with the power supply cable unplugged and jumped the way you suggested and the jumper on pins 3 and 4 of the main board, but when I take that jumper off the main board and unjump and plug the power supply cable back in, then it has a slow blink. Also, I noticed that when I plugged in AC with those jumpers in and the power supply cable jumped, I no longer had any audio as I did with things plugged in normally. Perhaps something is not working when I try the unplug and jump?
                      • mtnickel
                        • Jan 2017
                        • 31
                        By "a slow Blink", do you mean once every 5-6 seconds?
                        Mine did this too. It's an indicator of a fault. Some i think have said Drv reset.
                        Also, on the pn51f8500 I've been testing, to get the test images, the mainboard needs power. I know Hamie recommended to remove the power to the mainboard, not sure why. If that board doesn't get power, how will it fire up it's CPU and generate the test images?
                        But I wouldn't worry about generating test images since we know you know have a slow blink. I would first look to the X/Y main board since mine did exactly the same thing. You don't even have to pull it, just measure across all 3 terminals, 1-2, 2-3, 1-3. If you have a dead short on any of these pins on any fet, you likely have a problem. My replacement board for the pn51f6xxx was only like $16 shipped. check out how much a replacement is. May be worth it to try that next if it's cheap enough.
                        Regards,
                        Mark
                        • Hamie
                          • Apr 2014
                          • 1383
                          The control board generates the test patters not the mainboard.
                          On any other Samsung plasma with a separate control board you can generate test patterns without the mainboard. Usually the sustain board provide the power to the control board.
                          As previously pointed out I've never worked on this model. I'd be surprised If you couldnt run test patterns with jumpers inplace. But without a working model we my not know.
                          • Truncatedhose
                            • Oct 2014
                            • 343
                            Regards,
                            Mark
                            Thanks, Mark! By slow, I mean once every 1-2 seconds, haha, I guess my idea of slow is not as slow as yours!
                            I guess I will pull the X and Y and check all the fets and get back to you.
                            • mtnickel
                              • Jan 2017
                              • 31
                              Blinking every 1 second indicates the mainboard status is ok. So an overload fault may be less likely.
                              • mtnickel
                                • Jan 2017
                                • 31
                                On my newer samsung board (F series) board, the sustain board connected to the PS only has VS, VA, ground, and 15v. So in fact, the mainboard is actually supplying 5V to sustain boards (if it requires it), not vise-versa. So I maintain you probably need to power the Mainboard from the PS for that to work in this case.
                                On that samsung I've been playing with, I could only get a test pattern by jumpering the PS_on manually. This would turn the mainboard on to give a steady blinking LED. Without the jumper, the mainboard would just click on/off right away. Yours may not be that case as the unit failing to stay on is part of my problem. I left all other cable connections intact and displayed the test images just fine (with the 3/4 pin connected). I'm just trying to figure out why the unit won't stay on. In my case, I suspect a bad mainboard, but I already tried 1 replacement. Testing another next week.
                                • Truncatedhose
                                  • Oct 2014
                                  • 343
                                  Okay, so I tested all the components on heatsinks on the Y and X boards and the only shorted junctions I'm finding are on the X board: QS801C and QS802C read shorted (in both directions) only between the two pins adjacent to each other; they don't read shorted to the single pin by itself. This is in circuit; I haven't desoldered them. This an issue? Also, I had tried replacing this board, but it didn't solve the issue, but it's possible I got a bad board, I suppose.
                                  • mtnickel
                                    • Jan 2017
                                    • 31
                                    Pictures?
                                    Testing in circuit is usually ok. Is it a dead short (less than 1 ohm?). Also, I know on my board some parts looked like transistors but were just diodes. Could you read the number on their face?
                                    • Truncatedhose
                                      • Oct 2014
                                      • 343
                                      Pictures?
                                      I was testing in DIODE check, but when just checked with OHMS I found that both read 20.0 ohms either way between adjacent (side by side) pins. The number on both parts is: K15A50D. See picture attached. Thanks for your help!
                                      • mtnickel
                                        • Jan 2017
                                        • 31
                                        20 ohms could possibly be normal. I'm no circuit expert, but on mine, the dead transistors were a dead short. One would likely have to look at the traces, see what it's driving, etc. Maybe others with more experience can chime in.
                                        • mtnickel
                                          • Jan 2017
                                          • 31
                                          Did you try turning TV on with all cables connected properly and the 3/4 service pin jumpered? (instead of removing power to the mainboard).
                                          If so, what was LED blink like?
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
