Funai (Emerson) LF501EM4F not turning on
  • dick_barton
    replied
    Re: Funai (Emerson) LF501EM4F not turning on
    Originally posted by jayjoesph
    there is
    0.75vdc/76vdc
    0.74vdc/77vdc
    1.2vdc/47vdc
    Which set of leds is the 1.2V/47V reading from Led1, Led2 or Led3?
  • jayjoesph
    replied
    IS there more i can remove to bypass or trick the main board
  • jayjoesph
    replied
    Originally posted by dick_barton
    Shouldn't there be 3 sets of reading for Led1,2 &3 output?
    Edit,
    Reading yor reply again I see there are 3 sets of readings.
    Which led set is jumping up to 47V ?
    Sorry i should have worded that more clearly. the 1.2vcd is what was unstable of vled1
  • jayjoesph
    replied
    there is
    0.75vdc/76vdc
    0.74vdc/77vdc
    1.2vdc/47vdc
  • dick_barton
    replied
    Edit,
  • jayjoesph
    replied
    led connecor volatge is 0.75vdc/76vdc/0.74vdc/77vdc/1.2vdc<-(jumped up-down somewhat) 47vdc
    You did catch that R1108 R1208 and R1308 were removed correct?
  • dick_barton
    replied
    Can you confirm that with all the jumpers in place and the mainboard disconnected all the leds are powering on and the led voltages at the connector are identical. I think you said 78V in an earlier post.
    From what I can make out the 3.3V which should be measured at the Fault inputs to the Led Drivers (pin7) comes via R3189 in series with R3917, both 33K resistors, when Q3103 is not switched on.
    When any of the led driver are in Fault condition the corresponding 1K resistor at pin 7 is connected to ground though the IC's internal mosfet. Since these resistors are in series with R3917, this causes Q3013 to switch on.
    This will be the case for any of the led drivers should a Fault condition be activated.
    When Q3013 is switched on because of a Fault condition this results in the 3.2V you read across R3193
  • jayjoesph
    replied
    Would R3193 be the correct place to check? I read 3.2vdc on one side nothing or jumps to -0.000
  • jayjoesph
    replied
    Originally posted by budm
    OK, I just look through the service manual, there are two schematics for the main board, one is type 'A' and the Micro Controller is IC3005 (R8A05011BG-U0). The type 'B has IC3001 (MSD8200DS-S1) as the micro controller. The way PROTECT3 is connected is not the same for the two versions.
    So you need to find out which version you have by looking for IC 3005 (for 'A'), or if it has IC 3001 for 'B' version.
    okay mine says MSD8200DS-S1 and is a IC 3001 on the board
    replied
  • jayjoesph
    replied
    I only have the power supply board layout but not the mainboard layout so unfortunately I cannot help to locate it.
    well its BA31T0G0 201 3 If you can or anybody else can help out
  • dick_barton
    replied
  • jayjoesph
    replied
    The resistor should be on the mainboard and possibly close to IC3005
    Let me know if you see it i looked for least a hour top and bottem pictures and board itself
  • dick_barton
    replied
  • jayjoesph
    replied
    Somehow you will need to find out if that 3.3V gets all the way to those pull-up resistors or not.
    Thats gonna be fun I see them no where after searching zoomed in
    replied
  • jayjoesph
    replied
    c3660 reads 3.25vc P-ON+21v reads 21vdc and AMP+13v reads 13vdc
    http://www.tvparts.ca/images/product...2876462323.jpg
  • jayjoesph
    replied
    Well, you do have AL+3.3V at the main board connector, right?
    Yes i have 21vdc 13vcd and 3.3vdc at connection on main board side. I do have the flashing red led ever 10 seconds(steady lite with 1 blink every 10sec) as stated from the start
    replied
  • jayjoesph
    replied
    As you can see the diagram DIGITAL MAIN 5 in post 71, you see the pull-up resistor for the PROTECT3, see what you have both ends of the resistor.
    Yup I see that. No idea where to find those been looking no luck on either
