42"Fluid plasma tv Mod#(Samsung)pn50b550t2f
  • rich-t
    replied
    Re: 42"Fluid plasma tv Mod#(Samsung)pn50b550t2f
    bump
  • rich-t
    replied
    BuMP?
  • rich-t
    replied
    Ok, put my original board in. All were pretty close ( 0.1 ohm) except for 1 SE8117TA on pin 1 = 2.05v and new(?) one was 1.25 . Also 1 of the 1084PM reads different, pin 1 now =0v 2= 1.25v 3=2.50v . Very different from replacement but neither works, at least the new one allows me to turn it on with the remote as my old one did until I touched something wrong :-( I hope someone can help me. My coffee table still full of TV,
  • rich-t
    replied
    Yeah, but I have to go shopping first, my dog is hungry. :-)
  • vinceroger69
    replied
    can you put your old mainboard back in and take the readings on the same 3 voltage regs whilst your waiting for a answer budm may have a idea if these voltages are in spec or bad
  • rich-t
    replied
    Hi VR , main board was a exact mach an d had previously replaced power board and logic board.Will not get pic any more.
    So I've tested the v/regs voltages and I think 2 are suspect but I need a more experienced opinion so please speak up (TOM66) :-)
    The no's are AIC
    1084PM
    397H1 Vout 3.3 Vin 5v
    There are 3 of these, my readings are as follow useing the left pin as pin 1.
    First reg. 1=0.57 2=1.81 3=3.29
    Second reg 1=2.04 2=3.29 3.29
    Third reg 1=1.26 2=0 3=5.14
    Help?
  • vinceroger69
    replied
    sorry to hear the replacement mainboard hasnt fixed the issue was the new board a exact match all numbers etc? also what boards have you swapped now in this set?
    could the board you run the test patterns on be at fault? hopefully a more experienced member will know.
    also as this set did work at times do it still work sometimes now or not at all?
  • rich-t
    replied
    I'm going to try to test the voltage regulators (7) on the main board . I found a great video on the site, as it seems to me like a reg slightly out of wack could be the cause.
    I'll try to get it done tomorow.
  • rich-t
    replied
    thanks for the reply Reecey, DO YOU THINK IT'S THE main board thats the problem and is there a way to test it before I return it. (sorry about the caps)
    PS the boards all from different suppliers..
  • ReeceyBurger123
    replied
    The boards your getting must be faulty, or you have something like a broken wire.
  • rich-t
    replied
    Bump
  • rich-t
    replied
    Ah, the saga continues...... I finally got a main board from a gentleman who said it was fully tested and so it appears to me as the heat sink on the large chip in the center is askew and several caps have been marked with a black dot, so I installed this board plugged the tv in and VOILA,, I'm still at the same problem.
    I have replaced the PSU, the logic board and the Main board, still have no picture,can get the test pattern screen when pins 3 and 4 are jumped on the logic board. What I find stange is that when plugged in the stand-by light comes on and then a couple of clicks and I can turn on the blue light with it's accompaning couple clicks and the screen will flash a bit, I think it gets slightly lighter, but no picture and the remote no longer will do anything. I sincerely hope someone has some help for this problem. Thanks.
  • rich-t
    replied
    ok as it now wont turn on try heating each board see if heat makes it turn on start with power supply then the main board i use a hair dryer for roughly three minutes not to close or to hot as capacitors can explode with too much heat
    Thanks for the reply.I tried heating the big ic with the heat sink on top and no joy and I got it pretty hot but no change never tried any others but will give it a shot and also the power supply. MAYBE A LOAD BANG MAY BE A BLESSING.
  • vinceroger69
    replied
  • rich-t
    replied
    Back to square 1 now only stand by light, won't turn on blue light...sigh..
  • rich-t
    replied
    Ok, thanks, I'll try that.Finally found samsung parts and while they couldn't find my exact board a similar replacement is $539.00 lol, that's what I paid for the tv 8 years ago.
  • martino
    replied
    often problems that occur on start up are components that are on the edge of failure.
    When they are cold they have a different value then when warm.Might be just enough to work or not work.
    The freeze them,heat them can very nicely give away their secret so to speak.
    A voltage regulator that let's say has a output voltage of 1.8 volts,but when cold only gets to 1.65 volt can already be enough for a failed start.But when trying to turn on the tv a few times the temp inside that regulator has risen enough that it now gives 1.8 volt again and oh my,the tv works again.
    What i'm trying to say is that with freezing and or heating,you can sometimes find the area on a board where the bad guy is,and therefore close in on it.
    I have had boards that I froze first in the reactive areas and with solder iron touched each component one by one to find the bad guy. It sometimes helps,not always.In this case where it's hard to find a replacement this might be something to try,dunno.
  • rich-t
    replied
    Hi Martino, Thanks for the reply. As I stated in post # 1 this is an intermittent problem that only occurs on start-up. I don't know if this can be caused by bad connection? bad cap?bad chip? out of spec component? I think I need someone with experience in testing samsung main boards to chip in and help. If your that person fire away. I know how to use a VOM. and a soldering iron but not so much about electronics except for what I learned as a Mercedes Tech 20 years ago.
  • martino
    replied
    Did you measure the voltage regulators on the mainboard? Did you try to freeze sections of the mainboard to see if it has effect?(can of air up side down,short prays on target area).
    Did you try and heat up sections of the mainboard to see if it has effect?(hair dryer,paint stripper)
  • rich-t
    replied
    Thanks for the reply VR. I'll see what I can find out.
    Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
    by sam_sam_sam
    This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
    I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
    I am comparing them to a brand new one that I installed
    The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
    I going to let it run for several days before I remount back on the wall next to the...
    09-05-2024, 06:48 PM
    HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
    This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
    09-12-2024, 02:30 PM
    HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
    HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
    This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
    09-06-2024, 08:10 PM
    HP ProBook 450 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
    This specification for the HP ProBook 450 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + APC Back-UPS 700VA boardview and 450 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
