This Vestel LED has psu 17ips19-4 and main board 17mb95s-1. The fault is that on any backlight setting other than High and AUTO there is a pronounced screen flicker. Not sure whether its backlight failure as so far every backlight failur that ive had has been complete failure after perhaps a quick flash. This one appears to run with no problem on high and Auto backlight setting but if switched to medium or low backlight setting screen flickers badly. Any ideas??
Bush 40127fhd LED Vestel
Re: Bush 40127fhd LED Vestel
Checked what the drive voltage does when it flickers ? Could be failing Led driver Ic.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu... -
Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
The TV was stuck on the logo and I couldn't access the update menu.
I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
The image result was good, but the image is inverted.
The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in... -
by France_53Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
by lberkaniHi everyone,
I’m looking for the correct firmware for my Toshiba 65UL2163DG TV.
The mainboard is Vestel 17MB180E, and my panel is VES650QNTX-N2-N42.
The board I received is flashed for VES650QNDB_N41 and shows double “No signal”.
I need the correct USB update package (upgrade_mb180.zip / upgrade.bin) for:
- Toshiba 65UL2163DG
- Vestel 17MB180E mainboard
- Panel VES650QNTX-N2-N42
- Version V1.28.100.0 if available
If anyone has the file, please share a download link (WeTransfer, MEGA, Google Drive) and include version.txt... -
by hazi12Hello, board 17MB140TC, I need to change the remote control in Vestel tool box 1.1. The original is there
Rc48xx_2D and I want to install TOSHIBA-Rc481xx, but the program says that a maximum of 9 characters can be entered. I only entered Rc481xx and the program does not accept the driver I have in the original. Does anyone know how to do this? Other Vestel codes work.
I can send a dump.... - Loading...
