Samsung PS58B685 (like pn58b650). Sound but no image.
  • Wrecked
    • Dec 2016
    • 5
    • Denmark
    Hello all
    I could really use some help with this Samsung Plasma TV.
    It has been running fine for 6 years until a few days ago. Then the picture just disappeared. Screen went totally black, and the usual loud hum was gone. Audio still worked though.
    I took it apart and started debugging. Power supply board seems to deliver the voltages written on the connectors, and the logic board blinks every second. All caps looks fine! I then looked at the X and Y-mains.
    I found 2 pico fuses that was blown. One on Y-main, and one on X-main. I have attached pictures with arrows pointing at them.
    Then I measurred the Y-buffer, but no short was found. (not 100% sure I did it right, just saw a video on youtube about it)
    I did replace the 2 fuses with some of same spec (1A, 125V), and when I powered it on, sparks was flying, so I turned it off at once.
    The sparks came from 2 components looking like FET's on the Y-main board.
    Both the fuses I replaced were still OK.
    I have attached a picture of the burned FET's.
    Im not sure what my next step is now, and would like your advise.
    What baffles me, is that I found a blown fuse on both X and Y main. Otherwise, I would just replace Y-main and buffer boards.
    Anyone able to help me on this one?
    (I have meassuring equipment, and access to a scope if nessesary)
    Thanks in advance!
    Jimmy
  • Wrecked
    • Dec 2016
    • 5
    • Denmark
    Re: Samsung PS58B685 (like pn58b650). Sound but no image.
    Pictures:
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Hmm shorted fets on the Ymain and Xmain this set chains the erc meaning Y can kill X. You should replace the Ymain and Xmain or you could possibly go about repairing them which we could help with but it will be an involved process and there could be some explosions before it works. Up to you ?
      • Wrecked
        • Dec 2016
        • 5
        • Denmark
        Thanks for your anwser!
        I just bought a set of used X and Y mains on eBay. Are there anything else I should check or replace while Im at it?
        I guess I could double check the Y buffer boards for shorts, and also check for shorts between + and - of the input. But besides that?
        • Wrecked
          • Dec 2016
          • 5
          • Denmark
          Update:
          Got my used Y-main and on X-main from eBay this week, and just got around to try them.
          I meassured the Y-buffer again for shorts, but found nothing wrong, so I crossed my fingers and fired it up. The picture is back and everything seems fine, and as a nice bonus the loud hum is gone :-)
          Thanks for helping out!
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Awesome
            • wolf1976
              samsung ue40d6100 has no backlight no sound and image
              by wolf1976
              hi to all
              on the above model of samsung i have the faults i have told already on the title
              iI have standby i can from remote control open and close the tv and it seems reacts the tv when i press someone button from remote control but and with the help of a torch i cannot see anything image on the tv and no sound
              any idea from someone what can i measure so i can find the problem ?
              the power supply is the bn44-00482a i cannot find the service manual so i can test if the leds are ok and maby these are the cause of my problem
              11-17-2024, 01:02 PM
              09-07-2024, 05:50 AM
            • Francesc V.
              Samsung UE48J6200K - No image but sound
              by Francesc V.
              Hi:
              This TV turns on and it can show picture for some seconds (sometimes minutes) then picture freezes and fades away. What I've seen so far is that the T-Con (BN41-021101A) starts with three leds on, but as soon as led3 turns off, just 12V and 3.3V (the bold ones) remains in the PCB but all others disappear.
              If I remove the 2 bellow ribbons, LED2 never turns on. I was trying to look for the "T-CON ready" pin to shorten with 3.3V and then test just the TCON without the panel (haven't found it yet)
              Not sure how to proceed here..............how can...
              10-09-2024, 07:01 AM
            • Ierwin
              by Ierwin
              05-13-2025, 03:31 PM
            • ChaosLegionnaire
              by ChaosLegionnaire
              09-13-2022, 09:02 AM
