Vestel 17PW16-2 PSU low 12V & 24V Help!
  • cheeky2
    • Dec 2012
    • 337
    • uk
    This psu I have been playing with on a Sanyo CE42LD33-B 42inch TV. The 12V is around 11.6V initially then starts dropping down to 11.2V after warming up for around 10-15 minutes whilst it has been on. All the caps have been checked with ESR meter and are OK. I did notice whilst checking the feedback from the opto's that one of the resistors was higher than expecter 5.5K opossed to 5K within tolerance of 10% of resistor i only had a 4.7K so substituted that. A marginal increase in voltage but not significant 0.1V also replaced at the same time a 16V 1000uf capacitor which was slightly low capacitance around 940uf.
    So when the voltage drops to around 11.2V the digital tuner in the TV doesn't respond properly and epg goes out. Also if you shut the TV down it will not always boot up again once its reached around 11.2V. The 24V is around 23.5 and drops to around 22.8V. No problem with powering the inverter and screen displays fine.
    The main cap when switched on is around 370V C892 which I am not sure is high enough? All other voltages on the psu are pretty much spot on besides the 12V and 24V.
    So any help as to likely culprits would be welcome.
    I have attached schematic though some of the resistor values are different to psu (nothing unusual there though!).
    So any help with regards rectifying it are welcome.
  • cheeky2
    • Dec 2012
    • 337
    • uk
    Re: Vestel 17PW16-2 PSU low 12V & 24V Help!
    Just been checking the circuit I have found 18V across the 12V zener diode D854 which isn't correct if it is a 12V zener (diagram could be wrong again) as the resistor values are different compared to schematic.
    • Shotgun25
      • Feb 2014
      • 90
      I have one of these boards to repair.
      A few years ago I bought the following repair kit called MODKIT66A from the following link http://tidmanmailorder.co.uk/index.p...roducts_id=256.
      Kit contains the following
      Text on accompanying A4 sheet.
      "Vestel 17PW16-2 PSU Board. Replacing all the components should cure most known faults and improve reliability of the PSU. Based on Hitachi L42VP01U, Technika TVLCD40 & Wharfdale LCD42F1080P"
      Kit Contains
      F800 - 2.5A fuse
      IC801 - PC817 Opto
      IC802 - IC FAN7529
      IC806 - IC 01653
      IC807 - SG3525
      C877/8* - Capacitor 15nFd 1000V
      R830 - Resistor 0.22ohm
      Q803 - Transistor P10NK80ZFP
      Q837 - Transistor Yellow (?)
      IC825 - IC STPS5L25B
      D824 - Diode STTH12 +Insulation kit
      D851 - Programmable Zener Diode TL431 (W19)
      D836 - Zener Diode Blue (F2J)
      D866 - Diode UF5402
      C801 - Electrolytic Capacitor 33mFd 50V
      C817 - Electrolytic Capacitor 220mFd
      C892 - Electrolytic Capacitor 10mFd 50V
      *C878 may be 33nFd without C877 in some versions
      March 2009
      In the last year I've got a decent soldering iron and I've had enough practice to attempt the repair.
      I think the kit includes parts that are not needed for my model or are not direct replacements but are equivalents.
      Since this kit is for numerous models could someone review the following and advise me please?
      D824 - Diode STTH12 +Insulation kit (data sheet )
      The version I removed is B0872 F10L6OU (data sheet )
      The version I removed is EH14 FAN 7529 but the replacement is EA31 FAN 7529. I presume these are like for like but thought I'd ask about it.
      Do pins 4 and 9 have no connection on this PSU design? The pads lifted while I was wicking the solder up.
      I have looked at the data sheet and also the PSU design PDF linked here in another thread (https://www.badcaps.net/forum/attach...3&d=1478727993) it looks like they are optional. Having looked at the traces from the pins, I think they are unused.
      Please could someone confirm that.
      Just IC802 and IC806 to replace and then re-solder the large cap C819 covering IC807.
      • cheeky2
        • Dec 2012
        • 337
        • uk
        After looking at all the voltages on the psu and the main board it was found that there was around 0.4V difference on the 3.3V rail between the connectors. This drop in the resistance between the connectors was causing an issue with the TV not operating from the remote control when in the standby. I removed the connectors from the plug cleaned them up and now no issues with turning the TV from standby with the remote control. The voltage drop is now around 0.1V so i guess these connectors just deteriorate over time.
        • cadu
          • Nov 2012
          • Serbia
          cheeky2, have you solve the problem with voltage drop on 24v and 12v?
          BR,
          Dusan
          • cheeky2
            • Dec 2012
            • 337
            • uk
            BR,
            Dusan
            For convenience I replaced the power unit after thinking the issue was related to the low voltages on the power supply. I will at some time look at the old one with a view to repairing it. Though after cleaning the metal connectors on the psu it resolved the issue with the main board not coming out of standby with the remote control.
            In short to you answer no!
            • France_53
              Vestel tv, how to flip the image?
              by France_53
              Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
              05-12-2024, 05:22 AM
            • FlailingEngineer
              Help with Bush Tv (Vestel 17mb95m Mainboard)
              by FlailingEngineer
              Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
              Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
              05-31-2023, 06:52 AM
            • massimomax
              Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
              by massimomax
              Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
              spero che qualcuno può averlo per riprogrammare eprom. grazie
              Post in English !!!
              I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
              02-28-2025, 07:27 AM
            • Adenitz
              Troubleshooting Vestel TV, has standby, but cannot turn ON
              by Adenitz
              I need advice in troubleshooting Telefunken TV (it is actually Vestel). There is red Standby light but TV cannot be turned on either by remote control (which is good and tested on another TV) or by actual on/off switch at the back of the TV.
              Power board is Vestel 17IPS71 and I'm not sure about the mainboard, it seems like 17MB82S
              Both boards are shown in the attached photos.
              What is normally first that is checked in this case. I have removed power board, make sure it has no dangerous voltage on the big caps and check many components (transistors and diodes)...
              12-27-2023, 03:43 AM
            • Bazilwrc164
              Request: Firmware for Hitachi 42HXT12U (Vestel 17MB95M, VES420UNDL Panel)
              by Bazilwrc164
              I’m looking for a USB firmware file or EEPROM dump for a Hitachi 42HXT12U TV.
              The mainboard is a Vestel 17MB95M, and the screen panel is VES420UNDL.
              I recently replaced the mainboard with another 17MB95M, but it’s programmed for an LC420DUJ panel, and I’m getting no picture. I’d like to flash the correct firmware via USB or update the EEPROM if needed.
              If anyone can provide:
              • A working USB firmware file (like upgrade_loader.pkg or mb95_m.bin)
              • Or a compatible EEPROM dump
              07-23-2025, 12:15 PM
