50" plasma panasonic viera tc-p50x3 pcb main a board question
  • natas2001
    • Nov 2016
    • usa
    newly registered here but alot of research on and off last couple of months . I have 2011 panny plasma witb main board issues since day one of brand new purchase back in 2011 / 12 right off the bat the ethernet port never worked but knowing id never use it becuase of roku stick and satellite i didnt bother taken tv back for exchange .
    but over the years other ports started dropping off one by one leaving me now with only hdmi port 1 working ,
    question knowing the average cost if you can find one online is anywhere from low of $100 to $300 which even a 100 bucks is almost to me not worth it is there another way to maybe try and DIY fixing this board which my unit is tnph0911ac aka txn/a1pmuus pcb main -a
    ive done alot of google searches of diy repair but pretty much to no avail seem to always lead me to expensive purchase of new / refurbed board , i see other boards where they have " repair kits" available but nothing really on any main boards of any tvs not just panny's , i see no videos on u tube on possible way of trouble shooting main boards , just how to remove and install new board .
    are there or is there a possible trouble shooting solution to why my board sliwly is dying? a known problem to look for on these boards ? i see no puffy caps or anything noticable like a burnt board area , fuse .. etc...
    anyway appreciate any help on possible things to look for on the board or peplace that might be a possible swap out of cap or other part .
    thanks
  • Dani_2024
    by Dani_2024
    10-28-2024, 05:06 PM
  • ygorsan
    by ygorsan
    🧩 Problem Summary:
    • I
    07-28-2025, 08:34 AM
  • jb_Bak
    by jb_Bak
    CN6401
    Pin 01 NC
    Pin 02 NC
    Pin 03 "BL_ON": 0V
    Pin 04 "N/C"
    Pin 05 "STBY 3.3V": 3.5V
    Pin 06 "GND": N/C
    Pin 07 "AC_OFF"...
    09-27-2021, 04:52 PM
  • JDC
    by JDC
    ONN 100012588
    Long answer:
    07-15-2022, 07:39 AM
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
