Plasma Pixelization SAMSUNG PS50B430
  • creatou
    • Nov 2016
    • 12
    • France
    Hello everyone
    I would like the opinion of plasma experts. Attached is the picture of a Samsung PS50B430 50 "Plasma TV during test pattern in service mode. The image is polished by pixels that sparkle mostly on the green and blue.
    My voltages VS, Va, Ve, Vscan, Vcc, Vdd are correct.
    I unplugged the LVDS from the logic main board and switched it to test mode (shunt pin 3 and 4). The black snow is always present on all the pattern of test. I can eliminate the hand board is already that
    Do you have any idea of the cause of this defect.
    Thank you for your help. Sorry for my poor Englis I am just French
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Plasma Pixelization SAMSUNG PS50B430
    I would start by checking for poor solder joints on the board especially the X main.
    Any pictures of your boards?
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Xmain failure DO NOT RUN THE SET IT WILL KILL THE YMain, remove the xmain and its thermal pads and resdoler eveything mounted on a heatsink.
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        Good advice.
        • creatou
          • Nov 2016
          • 12
          • France
          hi,
          Thank's for your reply.
          I checked the welding on Xmain especially on the large inductors but nothing abnormal.
          I'll check again this evening.
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            A sharp clear picture of the underside would be more useful
            Does that board clip into another board which connects to the X drive ribbons?
            • creatou
              • Nov 2016
              • 12
              • France
              I make a picture as soon as possible. The picture was just to show the Xsus card model
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Thats a different Xmain thats used in this model ? Ive had a different Xmain on this model fail loads and it always kills the Ymain as they use chained Erc.
                • creatou
                  • Nov 2016
                  • 12
                  • France
                  Can you confirm the position of the boad on the attached image for my unit.
                  1: Ysus
                  2: Zsus
                  3: Xlogic driver
                  4: Logic board
                  5: main boaord
                  6: PSU
                  Which board appears to be in default?
                  ReeceyBurger123 said "Xmain"
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Ahh right it is just a newer revision of the set. What is your Ve running at ?
                    • creatou
                      • Nov 2016
                      • 12
                      • France
                      VE is 89V
                      Can you said me witch is the number of the board you name Xmain (see picture )
                      Thank's
                      • dick_barton
                        • Aug 2015
                        • 6642
                        • Wales
                        Board number 2 is the one I meant.
                        • creatou
                          • Nov 2016
                          • 12
                          • France
                          Here is the Xmain board solder side in two part. I have reflow all the joint and test ! no change idem with the Ymain.
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            I can see a few I dont like the look of reflow everything mounted on a heatsink as ve is good could be an Erc fault.
                            • creatou
                              • Nov 2016
                              • 12
                              • France
                              As I said I remade all the welds. the photo are before! Ve is OK. What is ERC default
                              Many thanks for your help
                              • creatou
                                • Nov 2016
                                • 12
                                • France
                                Yes ERC for the energy recovery circuit!
                                Do you think the panel may be faulty? Because a trace remains very quickly if I consult the menu for example but the trace disappears after.
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  What do you mean bud ? What is Vsc running at as well ? This does look more of a Xmain fault as nearer the Ysus the panel looks better but drops nearer the Xmain.
                                  • creatou
                                    • Nov 2016
                                    • 12
                                    • France
                                    Vsc is OK ! I have reflow all the joints on The Ysus.
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      Hmm might be worth upping Vs and Ve etc the panel isnt being sustained properly but could just be wear on the screen. Could also be worth doing a firmware update.
                                      • creatou
                                        • Nov 2016
                                        • 12
                                        • France
                                        The software update was my first step the software is the latest version.
                                        I attemp to up Vs but no change.
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
