Plasma Pixelization SAMSUNG PS50B430
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Plasma Pixelization SAMSUNG PS50B430
    Im quite sure you Xmain is the fault, as its nothing obvious have you got a scope to check the output of it ?
    • creatou
      • Nov 2016
      • 12
      • France
      Yes I have a scope. Wich waveform must be present? I have checked all the igbt, mosfet and diodes present on the heatsink one by one. All are OK
      • tn245
        • Oct 2013
        • 530
        I've currently got two of these open. One with a control board issue causing regular vertical lines across the screen, the other I bought as a "fully working" TV because someone was selling it cheap. Both of them with good control board in have a picture approaching what your photos show. Speckly mist, especially noticable on solid areas of green. They have big trouble with the "The Following Preview Has Been Approved For All Audiences" green splash screen before a trailer. Also some speckling in gradations of skin tone.
        Have checked voltages and reflowed joints with no effect. I'm thinking it's just crappy samsung plasmas and panel aging. I've worked on samsung panels in the past with similar maldischarge which I could never resolve completely. It gets better as the TV warms up and is perfectly watchable from normal viewing distance. There's also quite a bit of red sparkles when turned on from cold.
        Can you tell me how you get the firmware update on this TV? Can't find anything on google about how to do it. Will also try playing with voltages and timings after that to see what I can improve.
        • ducky29
          • Dec 2015
          • 369
          • Europe
          Please post a picture of the sticker on the back of your TV
          • tn245
            • Oct 2013
            • 530
            Yes, here are some pics. In fact one of them is a PS50B451, but both use the same S50HW-YB05 panel and identical boards.
            • ducky29
              • Dec 2015
              • 369
              • Europe
              #26
              If the VS and Va voltages match to the values printed on the board you should replace YSUS board
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                #27
                Doesn't make sence to me, what about testing the drive voltages generated by the Ysus to make sure its working or not rather than thorwing boards into it.
                • tn245
                  • Oct 2013
                  • 530
                  Yeah, I was going to say, seriously? Ysus bad on both TVs? Voltages are spot-on to spec on panel sticker. I'm going to play with some adjustments later to see if I can improve things at all.
                  Still haven't found out how to update firmware. Can anyone enlighten me?
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    #29
                    What about Ve whats that up to ? Might be best just to have a play see what you can do.
                    • tn245
                      • Oct 2013
                      • 530
                      Just been working on the B451. Ve was in spec. I had a play with voltages. Upping Vs and -Vsc improved things a lot. Then I finally figured out my way around the Samsung website and did the firmware upgrade and it got way worse. So I put the voltages back where they were and it's pretty good now. A bit of faint image retention and the green trailer screen still doesn't look solid color but normal scenes are very watchable. So just panel aging which the firmware adjusted for it seems.
                      • chrismurphy
                        • May 2014
                        • 251
                        • australia
                        #31
                        do not increase VS reduce it slightly this will improve an aging screen
                          09-07-2024, 05:50 AM
                          09-06-2024, 11:40 PM
                          09-06-2024, 08:40 PM
                          Samsung Galaxy Book Flex NP950QCG-X01DE Notebook Specification for Upgrade or Repair
                          This specification for the Samsung Galaxy Book Flex NP950QCG-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-X01DE boardview and NP950QCG-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          09-06-2024, 06:20 PM
