Hitachi 27 (1991) so many fishy badcaps!
  • Wizard
    • Mar 2008
    • 2296
    And rank.
    Nich and Rubyicons; TWSS and SME series, few big ones and about 40 little total ones; 4.7uF, mostly 10uF, some 47uF capacitors. Had to clean out the ooze too.
    Is that because of bad bung seal around the leads? And why did some use electrolyte that is very rank smelling like a ROTTING fish? Not to mention that smell get worse when desoldering them out. Make you feel like need to get repirator mask.
    Reason I did this looong recap job session is CRT is still excellent and high end model: has bass speaker box on top, S-Video and few inputs and one output with choice of internal speakers or external speaker outputs (unampified and ampified). Now excellent pic and audio. And to pocket the pay for the work. I work for TV shop.
    Cheers, Wizard
  • Oklahoma Wolf
    • Dec 2005
    • 353
    Re: Hitachi 27 (1991) so many fishy badcaps!
    I still have a Hitachi from 1975 sitting around here that used to be my grandma's. You'd think it was made yesterday, the picture is that bright and vivid on it. I've had to replace a few capacitors on it, but it's worth replacing a few caps to keep a good Hitachi in service
    • Jaime Morillo
      Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
      by Jaime Morillo
      Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
      The TV was stuck on the logo and I couldn't access the update menu.
      I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
      The image result was good, but the image is inverted.
      The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
      Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
      08-18-2025, 11:38 AM
    • wolf1976
      hitachi 50hk5600 problem with display
      by wolf1976
      hi
      i have the above tv and the display starts distorts the display at only in applications like you tube
      after and on the didital channels
      now without connect the antenna only the image of itsselfs tv i have the image i have in attach
      i have read in another forum someone else with similar problem with mine changes tcon card and motherboard and the problem remains
      can you tell me someone what is the reason that can causes that problem ? is the same the sisplay ?...
      09-13-2025, 02:26 PM
    • massimomax
      Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
      by massimomax
      Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
      spero che qualcuno può averlo per riprogrammare eprom. grazie
      Post in English !!!
      I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
      02-28-2025, 07:27 AM
    • dragometin
      Hitachi 40HYC42
      by dragometin
      TV Model: Hitachi 40HYC42
      Power Supply: 17IPS71
      MainBoard: 17MB95M
      Panel: VES400UNDS-2D-NO3
      When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
      I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
      Is there any variants on 17IPS71 power supply's?
      UART output pins 10 and 12 on scart connector:
      Code:
      12:24:04.595
      08-08-2024, 05:53 AM
    • sotodefonk
      Help finding the correct model of a T-Con board on my Hitachi TV
      by sotodefonk
      Hi, I have a Hitachi tv model L47V651, there is no image, but sound and backlights turn on, so I believe the issue is the tcon board.
      I opened the tv to access the board and took the shared pictures of the T-Con board.
      I saw a video from shopjimmy on how to detect the model number on tcon boards, but this doesn't have a sticker like how that video showed all boards.
      I searched the P/N number and got results with the same marking name and P/N my board has but they list other specific tv models like Vizio and Philips brand but not Hitachi.
      Inspecting...
      06-28-2024, 04:39 PM
