Samsung UN55D6003SFXZA not working
  • notaguitarhero
    • Nov 2016
    • 16
    Hey everyone, I've got a Samsung TV UN55D6003SFXZA that is not working. If I unplug the TV from the outlet, wait a few minutes, and plug it back in, the startup screen ("Samsung SMART TV") appears on the screen for a second before the screen goes dark. At the same time, the standby light blinks 5 times. And then if I try to press the power button, the standby light blinks once each time.
    I did a visual inspection of the power supply board and didn't find any issues. No burn marks, no capacitors that have exploded.
    I disconnected the main board from the power supply board, got the backlight to turn on and stay on, and measured the voltages at CNM803:
    1.) N.C. = 0V
    2.) N.C. = 0V
    3.) B13V = 12.74V
    4.) EPWM = 3.209V
    5.) B13V = 12.74V
    6.) N.C. = 0V
    7.) Vamp = 16.41V
    8.) BLU_ON = 3.005V
    9.) Vamp = 16.41V
    10.) GND = 0V
    11.) GND = 0V
    12.) GND = 0V
    13.) B5V = 5.37V
    14.) A5V = 5.37V
    15.) B5V = 5.37V
    16.) PS-ON = 3.359V
    I think it may be a main board issue? Ebay has one for $200 so I'd much rather buy a new TV.
    Power Supply Board: BN4400424A
    Main Board: BN94-05429D
    Any help is much appreciated!
    Re: Samsung UN55D6003SFXZA not working
    So far you have the correct dcv supplies and the control signals.
    So the next thing you need to do is to measure the DCV at each pin of the LED connector, you will leave the black probe on the chassis, red probe on the pin THEN turn on the TV to see what the Voltage jumps up to and then wait for a few seconds to see what it drops down to then turn off the TV, then repeat that with the rest of all the pins of the LED connector.
    • notaguitarhero
      • Nov 2016
      • 16
      Thanks for the reply budm.
      CNL802:
      1.) VF+ = 328V peak, 297V steady state
      3.) - = 200V peak, 177V steady state
      5.) + = 210V peak, 177V steady state
      7.) Dim- = 90V peak, 62V steady state
      I might not have grabbed the peak voltages, but they're around those values. I took a picture of the power supply board for your reference.
        How about pin 9 (F2), 10 (F1)?
        Also if you look at the transformer TM801S' legs, you will see the through hole rivets where the four legs of the transformer are soldered too, they are know for bad solder connection, you should resolder them, same for other components that use those through hole rivets.
          BTW, I also need a picture of the LED connector with the female connector in place so I can see how many wires are on that connector. So far it looks like it only have one big long string of LED, thus only one LED driver circuit.
          Pin 3 and pin 5 should be the same since it is connected together electrically.
          Vf+ pin 1 is connected to the Anode of the first LED string, the - pin 3 is the Cathode of the first LED string which is then connected to the + pin 5 which is the Anode of the second LED string, the DIM- pin 7 is the Cathode of the second LED string which is the return line to GND through the power MOSFET Q9102 and the current sensor resistor R9113 to Gnd.
          So after the backlights flashes on the Voltage at VF+ is staying steady at 297VDC as long as you do not turn off the TV?
          Per DC Voltage chart on the board, the LED supply Voltage is 330VDC, it sounds like you have some shorted LEDs.
          • notaguitarhero
            • Nov 2016
            • 16
            Transformer TM801S solder connections look good to me.
            See the attachment for a picture with the LED connector in place. 4 wires on that connector coming in to Pin 1, 3, 5, and 7.
            When I plug it in, VF+ reaches 328VDC, backlight is lit only for a second, and VF+ drops from 330VDC down to 297VDC as long as I don't unplug the TV.
            CNL802:
            Pin 1 (VF+) = 328VDC peak, 297VDC steady state
            Pin 3 ( - ) = 200VDC peak, 177VDC steady state
            Pin 5 ( + ) = 210VDC peak, 177VDC steady state
            Pin 7 (Dim-) = 90VDC peak, 62VDC steady state
            Pin 9 (IF2) = 0.6VDC peak and steady state
            Pin 10 (IF1) = 0VDC steady state
            If I indeed have shorted LEDs, what would be my next step?
            Thanks again.
              Can you check the resistance between pin 3 and pin 5? It should be <1 Ohm.
              • notaguitarhero
                • Nov 2016
                • 16
                Resistance between Pin 3 and Pin 5 on CNL802 is reading 0 Ohms.
                  That is what I thought it should be that is why it does not make sense in you DCV report on pin 3 and pin 5, they should be exactly the same since are directly tied together.
                  If it is bad LEDs, then you will have to take the panel apart to get to the LEDs, not simple job but we need to verify for sure first that it is LED problem.
                  • Packard93
                    • Jul 2016
                    • 81
                    SHINE A FLASHLIGHT OR BRIGHT LIGHT SOURCE if led if busted and u get pic . You know u got a backlight issue.
                    • notaguitarhero
                      • Nov 2016
                      • 16
                      How do I go about checking if it's an LED problem?
                      If I disconnect the main board from the power supply board, the screen lights up...so maybe it's not a backlight/LED issue then?
                        If that is the case then the power supply/LED driver and the LED backlights are OK, I should have ask you to perform that test first, sorry about that.
                        • notaguitarhero
                          • Nov 2016
                          • 16
                          No worries. So it looks like the issue is the voltages dropping (approximately 30VDC drop) at the LED connector.
                            It still does not make sense to me yet as to why the backlights do come on and stay on when the main board is not connected to the power supply-LED driver but the backlights will not stay on when the connection is back in place even and all the Voltages and the Control signals are OK. I am missing something.
                            • notaguitarhero
                              • Nov 2016
                              • 16
                              Is it the voltage drop that is causing the backlight to turn off? They happen at the same time.
                              With only the main board disconnected:
                              CNL802:
                              Pin 1 (VF+) = 325VDC peak, 322VDC steady state
                              Pin 3 ( - ) = 162VDC peak and steady state
                              Pin 5 ( + ) = 162VDC peak and steady state
                              Pin 7 (Dim-) = 1.1VDC peak and steady state
                              With everything hooked up (what I measured the other day, see earlier post):
                              CNL802:
                                The 297V will be too low. and based on that reading, the DIM pin is showing that the MOSFET for the LED return is not turn on so it shows 62VDC on the dim pin.
                                Are sure that:
                                4.) EPWM = 3.209V
                                8.) BLU_ON = 3.005V
                                Are present when the backlights go off?
                                • notaguitarhero
                                  • Nov 2016
                                  • 16
                                  Are sure that:
                                  4.) EPWM = 3.209V
                                  8.) BLU_ON = 3.005V
                                  My apologies, I might not have clarified what the configuration was when I measured those values. The voltages measured in the original post was with the main board disconnected (where the backlight was on).
                                  I measured the steady state values of at CNM803 with everything connected:
                                  Pin 1 (N.C.) = 0VDC
                                  Pin 2 (N.C.) = 0VDC
                                  Pin 3 (B13V) = 12.71VDC
                                  Pin 4 (EPWM) = 0.007VDC
                                  Pin 5 (B13V) = 12.71VDC
                                  Pin 6 (N.C.) = 12.66VDC
                                  Pin 7 (Vamp) = 18.88VDC
                                  Pin 8 (BLU_ON) = 0.14VDC
                                  Pin 9 (Vamp) = 18.88VDC
                                  Pin 10 (GND) = 0VDC
                                  Pin 11 (GND) = 0VDC
                                  Pin 12 (GND) = 0VDC
                                  Pin 13 (B5V) = 5.35VDC
                                  Pin 14 (A5V) = 5.36VDC
                                  Pin 15 (B5V) = 5.35VDC
                                  Pin 16 (PS-ON) = 3.30VDC
                                  • notaguitarhero
                                    • Nov 2016
                                    • 16
                                    To me, it seems like the issue is the main board. With the main board disconnected, the backlight lights up which probably means the power supply board and LED are fine. With the main board connected, I get the startup screen for a second or so before the voltages through the LED drop about 30VDC and BLU_ON drops to 0.14VDC.
                                    What would be the next diagnostic to do? Check TCON?
                                    To summarize the voltage measurements:
                                    CNL802 (connection to LED)
                                    With everything hooked up:
                                    CNL803 (connection to main board)
                                    Pin 1 (N.C.) = 0VDC
                                    Pin 2 (N.C.) = 0VDC
                                    Pin 3 (B13V) = 12.74VDC
                                    Pin 4 (EPWM) = 3.209VDC
                                    Pin 5 (B13V) = 12.74VDC
                                    Pin 6 (N.C.) = 0VDC
                                    Pin 7 (Vamp) = 16.41VDC
                                    Pin 8 (BLU_ON) = 3.005VDC
                                    Pin 9 (Vamp) = 16.41VDC
                                    Pin 10 (GND) = 0VDC
                                    Pin 11 (GND) = 0VDC
                                    Pin 12 (GND) = 0VDC
                                    Pin 13 (B5V) = 5.37VDC
                                    Pin 14 (A5V) = 5.37VDC
                                    Pin 15 (B5V) = 5.37VDC
                                    Pin 16 (PS-ON) = 3.359VDC
                                    Pin 1 (N.C.) = 0VDC
                                    Pin 2 (N.C.) = 0VDC
                                    Pin 10 (GND) = 0VDC
                                    Pin 11 (GND) = 0VDC
                                    Pin 12 (GND) = 0VDC
                                      OK, now it made more sense. At this point it is pointed to main board problem or something is locking out the main board from from sending the proper signals to turn on and control the backlights circuit. I would say main board is bad at this point.
                                      • notaguitarhero
                                        • Nov 2016
                                        • 16
                                        Yeah, I'll take a look at the main board again but I think there's not much I can do besides replacing it? It's pretty expensive and hard to find online. I'll probably just sell the parts for scrap at this point.
                                        I appreciate all the help budm. Definitely learned a lot in the last couple of days.
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
