Samsung UN55D6003SFXZA not working
  • martino
    Not so "senior"
    • Aug 2013
    • 997
    • canada
    Re: Samsung UN55D6003SFXZA not working
    Before you scrap it,I would be curious and dig into the panel,turn it on without mainboard and see if all led's light up. 55" smart tv is worth fighting for I'd say
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
    • notaguitarhero
      • Nov 2016
      • 16
      TV lights up with the main board disconnected. Main board is causing the issue, but a replacement is too expensive.
      • notaguitarhero
        • Nov 2016
        • 16
        Just revisiting this... I disconnected both the main board AND the LED connections, and noticed the voltages at the power supply pins cycle up and down - is this supposed to happen? There seems to be a sound (sounds like a cricket, if that helps) coming from TM801S every ~4 seconds, and after 90 seconds or so it stops making that sound. After disconnecting the power, the sound continues a few times before stopping. Does this mean the power supply board is bad?
        I've copied the pin readings from my previous readings for comparison and added the high and low readings with main board and LED disconnected.
        CNL802 (connection to LED)
        With only the main board disconnected:
        Pin 1 (VF+) = 325VDC peak, 322VDC steady state
        Pin 3 ( - ) = 162VDC peak and steady state
        Pin 5 ( + ) = 162VDC peak and steady state
        Pin 7 (Dim-) = 1.1VDC peak and steady state
        Pin 9 (IF2) = 0.6VDC peak and steady state
        Pin 10 (IF1) = 0VDC steady state
        With everything hooked up:
        Pin 1 (VF+) = 328VDC peak, 297VDC steady state
        Pin 3 ( - ) = 200VDC peak, 177VDC steady state
        Pin 5 ( + ) = 210VDC peak, 177VDC steady state
        Pin 7 (Dim-) = 90VDC peak, 62VDC steady state
        With main board and LED disconnected:
        Pin 1 (VF+) = 400VDC peak, drops in voltage, goes back to 400VDC after every other sound.
        Pin 3 ( - ) = 0.001VDC
        Pin 5 ( + ) = 0.001VDC
        Pin 7 (Dim-) = 0VDC
        Pin 9 (IF2) = 0.6VDC peak, drops to 0VDC, goes back to 0.6VDC after every sound.
        CNL803 (connection to main board)
        Pin 1 (N.C.) = 0VDC
        Pin 2 (N.C.) = 0VDC
        Pin 3 (B13V) = 12.74VDC
        Pin 4 (EPWM) = 3.209VDC
        Pin 5 (B13V) = 12.74VDC
        Pin 6 (N.C.) = 0VDC
        Pin 7 (Vamp) = 16.41VDC
        Pin 8 (BLU_ON) = 3.005VDC
        Pin 9 (Vamp) = 16.41VDC
        Pin 10 (GND) = 0VDC
        Pin 11 (GND) = 0VDC
        Pin 12 (GND) = 0VDC
        Pin 13 (B5V) = 5.37VDC
        Pin 14 (A5V) = 5.37VDC
        Pin 15 (B5V) = 5.37VDC
        Pin 16 (PS-ON) = 3.359VDC
        Pin 1 (N.C.) = 0VDC
        Pin 2 (N.C.) = 0VDC
        Pin 3 (B13V) = 12.71VDC
        Pin 4 (EPWM) = 0.007VDC
        Pin 5 (B13V) = 12.71VDC
        Pin 6 (N.C.) = 12.66VDC
        Pin 7 (Vamp) = 18.88VDC
        Pin 8 (BLU_ON) = 0.14VDC
        Pin 9 (Vamp) = 18.88VDC
        Pin 10 (GND) = 0VDC
        Pin 11 (GND) = 0VDC
        Pin 12 (GND) = 0VDC
        Pin 13 (B5V) = 5.35VDC
        Pin 14 (A5V) = 5.36VDC
        Pin 15 (B5V) = 5.35VDC
        Pin 16 (PS-ON) = 3.30VDC
        Pin 1 (N.C.) = 0VDC
        Pin 2 (N.C.) = 0VDC
        Pin 3 (B13V) = ~15VDC peak, drops almost to 0VDC, goes back to ~15VDC after every sound.
        Pin 4 (EPWM) = 2.9VDC peak, drops almost to 0VDC, goes back to 2.9VDC after every sound.
        Pin 5 (B13V) = ~15VDC peak, drops almost to 0VDC, goes back to ~15VDC after every sound.
        Pin 6 (N.C.) = 0VDC
        Pin 7 (Vamp) = ~16VDC peak, drops almost to 0VDC, goes back to ~16VDC after every sound.
        Pin 8 (BLU_ON) = 2.7VDC peak drops almost to 0VDC, goes back to 2.7 VDC ater every sound.
        Pin 9 (Vamp) = ~15VDC peak, drops almost to 0VDC, goes back to ~15VDC after every sound.
        Pin 10 (GND) = 0VDC
        Pin 11 (GND) = 0VDC
        Pin 12 (GND) = 0VDC
        Pin 13 (B5V) = ~3VDC peak, drops almost to 0VDC, goes back to ~3VDC after every sound.
        Pin 15 (B5V) = ~3VDC peak, drops almost to 0VDC, goes back to ~3VDC after every sound.
        Pin 16 (PS-ON) = 2.6VDC peak, drops to 0.9VDC, goes back to 2.6VDC after every sound.
        • martino
          Not so "senior"
          • Aug 2013
          • 997
          • canada
          So,I have the identical tv on the bench here and it has bad led's.
          Now when I have the mainboard connected it almost always triggers a fault and shuts down,BUT if I disconnect the mainboard the backlight comes on.
          Looking at it in a dark room I can clearly see a quarter section of the led's is not lit up!
          These are side lit,both sides.
          Conclusion I'm making is that the powerboard by it self does not trigger for led fault.
          I'm about to dig into this one,if you want pictures or measurements,let me know.
            09-07-2024, 05:50 AM
            09-06-2024, 11:40 PM
            09-06-2024, 08:40 PM
            Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
            This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
            09-06-2024, 06:20 PM
