LG 60pa6500 coloured lines
  • Stoutman
    • Oct 2016
    • 6
    I am having this problem with my lg 60pa6500. I have tested VA and VS voltages and they are bang on. All the caps look to be in good shape and I see no burnouts on any of the boards. I also checked for a short on the upper and lower driver boards and didn't find one (hoping I did it correctly). I do get a picture however I have these vertical lines with almost square pixel clusters of different colours. Any help with possible adjustments or an idea of which board may be bad would be hugely appreciated.
  • tw2005
    • Oct 2011
    • 6458
    Re: LG 60pa6500 coloured lines
    situation like this , I'm thinking logic control board and I'm pretty sure LG have them so you can run test patterns isolating the main AV board. If it was the same that would confirm logic, you just need the relevant manual or guide to confirm the procedure and the jumpers to short on the logic board
    • Stoutman
      • Oct 2016
      • 6
      Wow quick response on my first post. Thank you. I'll have to do some research on how to do what you suggest but I'm happy to have something else to look into now.
      • tw2005
        • Oct 2011
        • 6458
        If you open the image and zoom, bottom right there's two pads marked ext auto gen. they need to be shorted together and usually you disconnect the LVDS cable and the power cable from the mainboard. Then when power is applied to the PSU it should turn on and start generating test patterns, like solid colours and then maybe some patterns but if it's still scrambled as it is now them that logic board is no good.
        generally that's the way it's done but I'm trying to find a guide to confirm it but there's bound to be someone who's worked on the LGs more.
        I've never done it, just read of it
        Only $14 at shopjimmy too if it is
        • tw2005
          • Oct 2011
          • 6458
          Following Tom's advice in post #8 about test patterns, following that instruction it would appear they got the test patterns to generate.
          https://www.badcaps.net/forum/showthread.php?p=606849
          • Stoutman
            • Oct 2016
            • 6
            You're awesome, thank you! Much appreciated.
            • tw2005
              • Oct 2011
              • 6458
              sure, post up what you find, etc.
              • Stoutman
                • Oct 2016
                • 6
                Just got the logic board in today, installed it and everything is working perfectly again. Can't thank you enough.
                • howardc64
                  by howardc64
                  07-24-2025, 05:17 PM
                • polaro
                  Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
                  by polaro
                  Greetings,
                  I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
                  08-27-2022, 08:46 AM
                • Stanley1843
                  by Stanley1843
                  06-29-2024, 11:54 AM
                • jeyoung12
                  Samsung QN50Q60t lines on screen
                  by jeyoung12
                  Hi all
                  I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
                  My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
                  This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
                  It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
                  So....i don't know what end of the C ribbon to work with...
                  02-26-2024, 10:38 AM
                • ggil44
                  Sony XBR-65X750D Horizontal lines bottom of screen
                  by ggil44
                  Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
                  05-30-2023, 07:51 PM
