Samsung LN55C630K1F backlight issues
  • matomato13
    • Sep 2016
    • 31
    I decided to start a new thread since the last one was more about the power board issue (which I replaced). Here's the link to the old thread.
    Here's a recap of the problems I am having now with the backlight.
    • There's two inverter boards on this TV, I previously purchased two replacement boards that I never used.
    • I always had problems with the backlight on this TV (before the power board blew up). Sometimes I opened the TV and it would work for a few minutes or hours and sometimes the backlight stopped working almost immediately. Sometimes fast movement on the screen would trigger the backlight to stop.
    • After replacing the power board, I left everything intact and the backlight would appear 2 seconds on power up and would disappear before I could see the image.
    • I decided to replace the inverter boards, but didn't screw them to the TV, just left them floating around on the cables. The TV would turn on and the backlight would work correctly if I left it on the HDMI input (not connected to anything so black screen). If I changed to analog TV input (with the "snow") the backlight would turn off after 1-2 seconds.
    • When the backlight was working on the HDMI input I could hear a buzzing noise coming from one of the transformer on the inverter board. The noise would lower when I lowered the backlight brightness in the menu.
    • I replaced the inverter board that was causing the noise, still leaving it hanging on to cables not touching the TV. No more buzzing noise but still the same problem, works with HDMI input and turns off with the analog TV input.
    • I left it 5-10 minutes on the HDMI input while I was doing something. Came back and changed to analog TV input and the backlight stayed open for a long time (turned off the TV before I could see it turn off by itself).
    • Decided to put back the screws on the inverter boards and now the backlight turns off just before the image is visible, just like before I decided to unscrew it.
    • I removed the screws, still working, put one screw back and no backlight (only the 2 seconds flash before image). The screw is, I think, used to ground the inverter boards (if you look at the image, you'll see what I mean).
    Here's a link to the two inverter boards
    http://www.shopjimmy.com/auo-19-54t0...t-inverter.htm
    So that's a good recap of where I am now.
  • matomato13
    • Sep 2016
    • 31
    Re: Samsung LN55C630K1F backlight issues
    Any help?
    • Nick's Tvs
      • Jan 2014
      • 621
      Sounds like you have bad ccfl that will need to be replaced. This is going to be a very difficult, time consuming and delicate procedure as you will want to remove the screen from the set and take a look at your CCFL lamps. First I would set the brightness down as low as possible so that you may keep the backlight on when you plug it back in while the lamps are exposed. Then just look for any of them that may be dim, discolored or pinkish looking. You may have 1 or more bad lights.
      • matomato13
        • Sep 2016
        • 31
        What do I do once I find the bad CCFL lamps? What can I find one for my TV model?
        • matomato13
          • Sep 2016
          • 31
          Help? I couldn't find a disassembly guide for the TV either sonI can't get the part numbers for the ccfl.
          • triplefour
            by triplefour
            09-13-2023, 10:43 PM
          • CaptainBucko
            Acer ER320HQ backlight issues
            by CaptainBucko
            I have two Acer ER320HQ monitors. Both have dark background (I presume backlight issues) in on the left and right hand sides of the screen. Otherwise image is clear. Can these be repaired? The monitor is supplied externally with 19v DC and I have confirmed that supply is good and stable. Any further thoughts or pointers?...
            12-18-2024, 06:09 PM
          • PJK65
            ASUS Q502LA LED Screen/Backlight Issues
            by PJK65
            Hello Everyone.
            Glad to be a member here! I am pretty new to working on laptops. I was hoping I was going to able to fix this one, but I am having some problems...
            This laptop works perfectly with a HDMI monitor hooked up to it. Here in lies the problem. No backlight! So i figured, replace the screen/backlight assembly. Then I had very dim video (could be seen with a flashlight) but still no backlight. Found after doing some homework that it had a blown ferrite bead, which I replaced. Like an idiot, I forgot to unplug the battery, and when I was hooking back up the 30 pin cable,...
            02-24-2023, 04:47 PM
          • DanPoka
            by DanPoka
            02-15-2025, 05:05 AM
          • Comp_Pro
            No Backlight Macbook A1990 820-01041
            by Comp_Pro
            Hello all,
            Am trying to figure out this backlight issue with this A1990 Macbook Pro.
            Tests performed:
            There is no backlight even with a good screen.
            Backlight IC is receiving the correct support voltages.
            Fuse F8400 ok
            Current sense resistor R8400 ok
            Backlight IC is receiving 3.3V on enable pin.
            Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
            Backlight IC receiving 5V from PP5V_G3S
            Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
            I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
            05-06-2024, 10:23 PM
