Samsung 40F5500 red light blinking
  • ovidiu.buzzi
    • Oct 2016
    • 10
    • SPAIN
    Hello to everyone on this forum.This is my first post on this forum and hope i will post well and not upset anyone.I have a 40 inch led smart tv samsung that have like 1 year of use very light use.it was ok before going to bed ,in the morning when i woke up the red light was blinking.I did open the tv it has a BN-4400645A power board.I look for the back light though the holes and is blinking not staying on which i was thinking is a power supply board.I don t see any bad caps the board looks like new .the voltages i did measure are.
    1- 12,8
    2- 2,98
    3- 12,8
    4- start from 20mV and goes up until 80mV and upper
    5- 12,8
    6- 2,98
    7- 12,8
    8,9,10- GND
    11- 5,32
    12- 5,32
    13- 5,32
    14- 3,33
    My question is also on the upper side of schematics the voltage out of the 4 diodes it say 120V V_DRV and i get only 99 -100V.
    Thank you and hope i did well my first post
  • CapLeaker
    Leaking Member
    • 8123
    Re: Samsung 40F5500 red light blinking
    Backlight LED's failed / failing. I am afraid you have to take the panel apart.
    • ovidiu.buzzi
      • Oct 2016
      • 10
      • SPAIN
      But is not turning on the TV even if i press the power button red light still blinking.I was thinking that it is possible to be backlight only if is turning on and you hear a sound or something but mine is alway blinking.I i disconnect the board from icon you can see though the hole how is blinking the backlight
      • ovidiu.buzzi
        • Oct 2016
        • 10
        • SPAIN
        So i am coming with updates......after a week of letting the tv on the table with all the boards disconnected i tried again to make some measurement but tv turned on and was working with no problem for 1 day after that the next day while watching it it started to reboot itself 3 or 4 time and didn't t power on life it did the first time and the stand by light is blinking with no reason without touch any remote or button.
        • Moreno83
          • Jun 2014
          • 2008
          • The Netherlands
          Hi ,
          What you can do is turn on the tv. It will probably start with the blinking pattern. If so then take a heatgun/hairdryer and heat up the powersupply when the tv is blinking , see if it will turn on after a few minutes. If so then you have a problem on the powersupply.
          • thoma
            • Sep 2012
            • 268
            Disconnect cable between mainboard and Powersupply!
            What happens?If you have backlight your mainboard is defect!
            Disconnect cable mainboard T-Con
            What happens?
            • ovidiu.buzzi
              • Oct 2016
              • 10
              • SPAIN
              Coming with updates Moreno83......you were right it was blinking i did use a hair dryer and after 30 40 seconds it did turned on by itself and works so that means is a power board problem........it means that is an imperfection on the board or is there any component that is bad like a bad cap that you can not see.do i have to heatgun the board??? thank you
                It can be bad caps with high ESR. When cap is heated up the ESR will go down so the circuit will function again. BTW, bad cap can look normal.
                Or can also be cold solder joints. I would resolder those transformers' legs and the legs of those devices mounted on the heatsinks.
                • ovidiu.buzzi
                  • Oct 2016
                  • 10
                  • SPAIN
                  ok so i did change all the caps on the output but no luck also resolver transformers and the devices mounted on the surface but still no luck and the stand by light still blinks......could that be the transformers since sometimes is working sometimes not???i don t know what else to check.....i know that is not the mother board
                    So when you heat up the board and it will function. So was that before the caps were changed or after the caps were changed?
                    And you did not change the caps in the primary side at all?
                      Btw, those Voltage readings in post 1, were they taken when the TV is working or not working?
                      • matty24
                        Samsung UE50MU6172 - red light blinking
                        by matty24
                        Hello. I have problem with Samsung UE50MU6172.
                        TV won't turn on, red standby light is blinking.
                        Power supply BN44-00807A is fine. I replaced it with the new one.​
                        Main board BN41-02568B (BN94-12530E)
                        I've read a dump (W25Q40CL). Can someone check it od fix it for me?...
                        03-02-2025, 08:57 AM
                      • Fergal22
                        Samsung UE40F5300AK blinking red light
                        by Fergal22
                        I have the above tv that just shows a red light blinking twice 5 times, i have taken the back off and all the capacitors seem ok,
                        When i disconnect the mainboard from the PSU all the led's light up blinking fast but as soon as i reconnect the mainboard back to the power supply i get the red light blinking again twice 5 times,
                        I have attached pictures of the Mainboard, PSU and a small video (zipped) showing what happens when i disconnect the lead from the psu
                        Any help would be appreciated...
                        02-02-2023, 09:19 AM
                      • norbiszoke
                        Samsung 50AU7172, only blinking red light
                        by norbiszoke
                        We have this set here in our shop that is not ginving sign of life besides red light that is blinking one time after pressing the button and nothing more... After detaching the mainboard from the PSU (this set has separate board thank god?! or not...) the backlight comes on. After reattaching nothing besides red light.... Can anyone from the forum help me here? Thank you in advance. Here's a link with images of the mainboard and the memory IC's that are on it.
                        Regards, Norbert!...
                        04-17-2024, 06:54 AM
                        09-07-2024, 05:50 AM
                      • 3DDD
                        Samsung UE46D6100 LED TV blinking red light indicator
                        by 3DDD
                        Hello, I have a Samsung UE46D6100. It cannot be turned on, only the red status LED flashes, the power supply part bn44-00458a gives an output of 5V(A), it is probably functional. I don't know where to look for the error, according to the video it should be a faulty mosfet. I found a mosfet marked WAAH, I don't know what it is. Can anyone help me?...
                        02-20-2025, 12:51 PM
