SMD Fuse part # for replacement
  • culcuhain
    • May 2016
    • 186
    • U$@
    My TCON board (see my LG post) has a blown fuse.
    The silkscreen by it is 63V 1.5A.
    The marking on the fuse is TK.
    I don't know if it is a slow blow, fast blow, or ultra fast blow.
    Does anyone know of a replacement one for it? I prefer Mouser as they are local.
    Anyone help?
    Thanks!
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: SMD Fuse part # for replacement
    Ebay says
    Fuse 1.5a SMD 1206 Antisurge 63v Marked TK Size: 3.18mmx1.52mmx0.58mm
    List of fuse types
    http://www.edaboard.co.uk/smd-fuse-codes-t525460.html
    • culcuhain
      • May 2016
      • 186
      • U$@
      Thank you!
      • the_rem
        Unknown transformer : how to find a good replacement part ?
        by the_rem
        Hello guys,
        I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
        I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
        04-23-2025, 01:48 AM
      • FreakyMex
        Trouble to identify part (Lunii screen) for replacement
        by FreakyMex
        Hello guys. I'm a complete noob in electronics. I'd like to repair my child Lunii's (a "story box"), basically an audio player that allows the childs to choose between several options the places, characters, objects of the story, and then play a story according to the choice of the child. There is a screen that display the selected option before each choice. The Lunii fell and the screen is now broken.
        I'd like to repair it (probably just have to change the part, because the lunii still works perfectly fine) but I can't manage to identify the part/order it online. Do you have any...
        02-17-2025, 01:16 AM
      • socketa
        Bestec ATX0300F5WA - fast,or slow blow, fuse?
        by socketa
        I bought a dead motherboard, and connected it to this PSU,
        Was checking the standby voltages on the motherboard, and, whilst doing so, the PSU made a loud bang with a flash of light.
        So now i truly got a bang for my bucks, and something else to try and fix.
        The fuse was blowen, and the top was blowen off of a TNY276PN chip
        The glass fuse didn't have any marking to say if it was fast or slow blow
        So i checked the marking on the PCB thinking that that would tell me,
        but it 's got a T/F8A printed on the board
        So should i get a fast blow fuse, or should...
        05-17-2022, 01:22 AM
      • drykid
        Matsui 175S microwave fuse replacement
        by drykid
        I recently picked up a used Matsui 175S microwave that was powering up (starts, turntable rotates) but not heating. From looking online the most likely culprit was the fuse, but unfortunately in this one the fuse had heated up and fused with the (badly designed) fuse holder and couldn't be removed. I guess this might indicate further issues beyond the fuse itself but at this stage I just want to replace the fuse and see how I go from there.
        Anyway since I couldn't get out the fuse itself the easiest fix was to replace the fuse holder assembly that runs between the...
        12-21-2020, 01:15 PM
      • whc14765
        Replacement Fuse - 980TI Gigabyte
        by whc14765
        I have a GIGABYTE Windforce 980TI with a blown fuse. I have already found the root cause for the fuse blowing.
        I need help getting a replacement fuse - I'm fine with waiting some time for some cheap ones from China.
        The fuse says 10A on it. And I'm not sure what package size it is exactly. Also, how do I know if it is a fast or slow fuse?
        04-11-2022, 09:01 AM
