50PC1D Help Psu Shutting Down ?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: 50PC1D Help Psu Shutting Down ?
    I had already replaced the caps before it blew, with vlesr Pannys so thats not the cause. I had also replaced the heatsink on the Mb and added one to the Tcon Bga Ic as preventative measures dunno if you've seen my vid on this set ? I do that all the time before testing, replace them caps.
    These are full of faults, you heard of the Zsus fault where every 45F122 IGBT shorts I think over 9 in total blow lol. Would you sell me your sus boards or whole Tv lol ? If not it will have to be put aside for a few weeks like thw PC1D.
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      Nah--with mine, Defo PSU issue as I swapped out its original to repair a set with this fault--leaving me with this intermittent PSU--And the VZ-Bias blow-up, like yours....
      Bloody things haunt me these days!
      TELEFIX
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        Ive got a 50PC1da --actually two of 'em if you're interested....
        TELEFIX
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          I might just bin this and the PC1D running out of time and space at my nans house and my place. I love Plasma but they just take so much time up.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            What are the faults matey ? Also got stands and remotes ? And screens in good condition ?
            • Alastair E
              Chief Womble
              • Mar 2013
              • 1963
              • U.K.
              #26
              No remotes one works--but has repaired IPM and one stand between 'em.
              Other Ive had for ages--haven't even plugged it in!
              TELEFIX
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                #27
                Id buy them but how much for your PS3000 really dont know if I can be arsed with this one ? I cant drive yet f bud but 4 weeks till my test, can easily get the, in my Corsa as well.
                • Alastair E
                  Chief Womble
                  • Mar 2013
                  • 1963
                  • U.K.
                  #28
                  Swap you the PS (with hopefully good psu) for the two PC....?
                  TELEFIX
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    #29
                    Deal, send me a Pm on facebook to arrange this
                    • PlasMatt
                      LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                      by PlasMatt
                      I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                      09-20-2025, 06:50 PM
                    • Maniackk
                      Yoga 530-14ARR NM-B781 Ryzen 3 2200 – overheating and shutting down under load
                      by Maniackk
                      I’ve got a stubborn patient here. The laptop powers on and works, all components like the screen, keyboard, touchpad, etc. are functional. The issue is that it heats up very quickly under load (within a few minutes up to 95°C) and then shuts down shortly after. Subsequent attempts to turn it back on right after a “hot shutdown” result in it shutting off within a few seconds. Interestingly, if I enter the BIOS, it can stay there for 2 days without shutting down (most likely due to low CPU load and low temperatures).
                      The cooling system has been cleaned, thermal...
                      09-03-2025, 09:32 AM
                    • legg
                      LG 42PC3 buffer output doesn't follow YSUS
                      by legg
                      LG42PC3D -UD originally with green lamp but no display or audio.
                      Owner says was working, then went 'pop'.
                      All 5V caps bulging. replaced.
                      All PSU output voltages within spec but -Vy is low on YSUS.
                      One of three parallel fets between SUS_OUT and SUS_DN is zenering,
                      eventually shorts DG. Replaced all 3 - -Vy now OK.
                      Y scan buffer test point does not follow YSUS output below -50V
                      Note: This unit seems to expect YSUS output to park at -Vy in between
                      drive signal pattern periods. A replacement drive signal board confirms this....
                      11-18-2021, 11:49 AM
                    • Truncatedhose
                      Help repair this relic? Philips 42PF7220A/37, pulsing buzz from YSUS
                      by Truncatedhose
                      Greetings all!
                      Originally this set had the usual messed up video symptoms such as: horizontal lines, weak, grainy video, bottom and top of picture differ in intensity of problem. It also seemed to slow to turn on or show the messed up picture.
                      Seemed like must be YScan/buffer board failure. Ordered buffer boards from my distributor which were supposed to be original/new and also from another distributor, I ordered the YSUS because I wanted to replace it for preventative maintenance. (also, the YSUS had a bulged cap, so there was even more reason to suspect it could...
                      07-04-2018, 10:59 AM
                    • Max Leo
                      Model A1398 (EMC 2909) adapter unable to read or detect
                      by Max Leo
                      i connect with this adapter unable to read or detect do i have to do something or short something to read the bios...
                      10-30-2025, 07:58 AM
