50PC1D Help Psu Shutting Down ?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Just need some suggestions before I crack the sope out on this old fucker. 2006 Lg Hd Plasma, originally had failed 46N15 transistors on the buffer and a shorted IPM (ERC track shorted) on the Ysus as well as the Psu having about 13 bad Samwha WL caps, however the Tv did switch on just gave a flashing image due to failed Ysus etc.
    I repaired the Ysus and buffer, as well as recapping the Psu fully apart from primary's. Now Im greeted with a clicking Psu with or with out Ysus/Zsus connected.
    Vs charges then shuts down followed by a click from the relays. Everything is soldered properly and the repaired boards dont not have any shorts. The AC Detect and RL-ON/VS-ON are perfect until shutdown and all voltages are present.
    Any suggestions going to put this aside for a few days before I smash it up lol I know the power supplies are known to have issues but these 50PC1D's are a bloody nightmare riddled with faults. Let me know cheers chaps
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: 50PC1D Help Psu Shutting Down ?
    I got two of these Behemoths in the W/S at the mo....
    Dunno just what to do with 'em. One Ive rebuilt an IPM with DG502's and it runs fine, The other Ive had for months but haven't looked at yet, for fear of breaking my back!
    I do know, the AC Detect has issues--but never had them myself. Apparently, even the Great Tom hasn't figured that one out--but Fecked it to work by shorting two opto's...
    Usually just IPM's and PSU Caps, maybe the odd Mainboard fault is all that happens--The 50's are usually free of the Mal-Discharge the 42" has, and have a reasonable picture.....
    Quite a good set--They ARE now 10 odd years old, usually up at 25,000 odd hours, not bad really, There's many other sets much younger and totally stuffed...
    Also, Ive Never seen a dead COF Chip on any PC1D/A set, maybe due to that Massive heatsink all along the bottom!
    TELEFIX
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Cheers Ali, they are good build quality I like the fan design too works well and yes the panels are very reliable in these due to the huge heatsink if only they all used heatsinks like that on the address buffers Plasmas could live forever. Also yeah my Ac detect stays at 5v so Ive no idea what is shutting it down.
      I might repair the orginal Ipm and stick that back on rule that out but Im quote sure this is a Psu failure on this one, just takes alot of time to diagnoses it and Ive not got the effort for this as it only will sell for £180. I do get all sus voltages Ie VSC, Vy etc but nothing obvious is causing it to shutdown. Got any ideas let me know
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        Bugger me! £180 for a 50PC1DA!
        I would be lucky to get £130! I sold a Panasonic 50X20 for £150 just last week.....
        TELEFIX
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Yeah sales quite good round my area
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            Originally posted by reeceyburger123
            yeah sales quite good round my area
            +1
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Still not got around to this, ahhh I need to diagnose the bastard no motivation though
                I'd check and see if the low voltage rails (15V, 5V?) shut down before the Vs/Va.
                You can use a scope to do this.
                That will give you a clue, the other rails won't run if the sub rails shut down (protection, and also the Va circuit loses drive power)
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Cheers Tom, its just effort I want to sort this as put alot into it. But Ive got loads of others to get on with will have a play probably tomorrow.
                  • flocko
                    • Nov 2012
                    • 1121
                    • uk
                    I can recall repairing a set of this model a few years back, that when trying to improve an image problem, adjusting Vs+Va the power board would go into shutdown if you dropped the voltages to low,turning the trimmers (voltages)back up would restore it after a restart with the remote. try running with unplugged Y+X see what voltages the power board is putting out
                    • Alastair E
                      Chief Womble
                      • Mar 2013
                      • 1963
                      • U.K.
                      Yes--Now you come to mention it, I remember messing round altering Va and Vs it shutting down.
                      It would go off with a huge Bump through the speakers! Rather alarming--sounds like its destroyed summit, but its just the PSU cutting everything--all at the same time.
                      TELEFIX
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Hmm interesting I cant remember playing with Vs Va, however the panel does sort of half prime then it shuts down. Will have a play tomorrow, I did the same on a 50PG3000 but after a hard reset the set worked even with the pot in the last position.
                        • flocko
                          • Nov 2012
                          • 1121
                          • uk
                          Yes Alastiar the same bump though the speakers you got if you tried Toms AC detect power board fix ,shorting the opto, very alarming and sounds like an expensive blow up
                            Yep, only happens because power board loses power then half a second later goes "wait...my bulk capacitors are empty...SHUT IT DOWN BOYS!"
                            If you have working AC detect, the main board realises before it's too late and cuts the power to the audio and plasma panel.
                            I would second checking Vs/Va, I believe it's actually if Vs or Va are overvoltage that it will trip, can happen if the pots are tuned too high.
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              Hmm well its not Vs or Va, with Ysus connected Vsus is way too low only 120v before shutdown with Ysus/Zsus out its 195 before shutdown which is what the panel spec is also lower drive voltages are fine. The control board Leds seem to change pattern some times as well but my sus voltages are mostly correct.
                              Just got to sort another 50PS3000 atm but will get back to this later.
                              • Alastair E
                                Chief Womble
                                • Mar 2013
                                • 1963
                                • U.K.
                                They do trip at Under-Volts too...
                                Both too high and too low will give shut-down with bump...
                                --I remember that when playing with the Va and the Vs on one of these...
                                TELEFIX
                                • Alastair E
                                  Chief Womble
                                  • Mar 2013
                                  • 1963
                                  • U.K.
                                  Whats up with your 50PS3000, --Ive got one that most of time wont start up. When it does--it runs fine...
                                  TELEFIX
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    The PS3000 is a bastard lol, shorted SMP driver Ic on the Ysus covered in glue near the transformer nearest the Tcon. Replaced that, short from 5v line on Ysus went set worked
                                    Hours later Zsus failed Vzbias circuit up in flames, 3 fets short and resistors blown. Got that on order now. Fancy selling me yours ? Before I smash this one up lol because now the short on the Ysus is back after the Zsus blew.
                                    Also Ali on yours I would say it has a Bga solder issue. These PS3000's are shit Tv's riddled with faults with all boards and the panels !
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      Also on the PC1D hooked up a light bulb as a load in series with Vs, psu still shutting off. Pfc bus is working so I suspect something on the feedback is gone but struggling for time atm. Bloody Lg fucking shit Tv's hate these more than VESfuckingTEL !
                                      • Alastair E
                                        Chief Womble
                                        • Mar 2013
                                        • 1963
                                        • U.K.
                                        I can tell you--the 50PS VZ-Bias issue is ALL the tiny caps on the Control-Board!
                                        --Dunno the failure-mode, but replacement stops the reg and the mosfets in the VZ-Bias on bottom heatsink from heating and shorting, and taking out that WW series-resistor...
                                        TELEFIX
                                        • legg
                                          LG 42PC3 buffer output doesn't follow YSUS
                                          by legg
                                          LG42PC3D -UD originally with green lamp but no display or audio.
                                          Owner says was working, then went 'pop'.
                                          All 5V caps bulging. replaced.
                                          All PSU output voltages within spec but -Vy is low on YSUS.
                                          One of three parallel fets between SUS_OUT and SUS_DN is zenering,
                                          eventually shorts DG. Replaced all 3 - -Vy now OK.
                                          Y scan buffer test point does not follow YSUS output below -50V
                                          Note: This unit seems to expect YSUS output to park at -Vy in between
                                          drive signal pattern periods. A replacement drive signal board confirms this....
                                          11-18-2021, 11:49 AM
                                        • Truncatedhose
                                          Help repair this relic? Philips 42PF7220A/37, pulsing buzz from YSUS
                                          by Truncatedhose
                                          Greetings all!
                                          Originally this set had the usual messed up video symptoms such as: horizontal lines, weak, grainy video, bottom and top of picture differ in intensity of problem. It also seemed to slow to turn on or show the messed up picture.
                                          Seemed like must be YScan/buffer board failure. Ordered buffer boards from my distributor which were supposed to be original/new and also from another distributor, I ordered the YSUS because I wanted to replace it for preventative maintenance. (also, the YSUS had a bulged cap, so there was even more reason to suspect it could...
                                          07-04-2018, 10:59 AM
                                        • zwarder
                                          eax61319402 50PJ350 YSUS
                                          by zwarder
                                          Hi
                                          Had shorted YSUS
                                          Q24 RPJ63F3
                                          C726 cap
                                          Q11 K3667
                                          R528 & R529 2.2 ohm
                                          replaced all of these but still trips psu VS & VA are a bit low when ysus disconnected. IC301 does look a bit burnt however
                                          ZSUS is also good as far as I can tell
                                          Anyone could help me out on this one
                                          10-23-2023, 08:11 AM
                                        • pabloroggeri
                                          Lenovo V360, no detect battery
                                          by pabloroggeri
                                          Hi friends!
                                          It does not charge or detect the battery. At first it didn't start, I programmed the BIOS with the file that is in this forum and it turned on but it doesn't detect a battery. I need to try another bios that is not the one that is already published in the forum, I suspect that the one I recorded is corrupt, or incompatible in some detail and that is why it does not detect the battery. I did all the measurements on the charguer integrated circuit and they are all ok. I think the problem comes from the data BUS side. It is for this reason that I need a different...
                                          07-28-2022, 08:18 AM
                                        • tikanot
                                          msi GP63 gtx not detect and keyboard mistake
                                          by tikanot
                                          Hello i have a msi GP63 and the gtx 1060 is not detect in the bios and not detect in windows , i have flash the vbios with programmer and same mistake, i have the ec do mistake with keyboard key not work or keyboard not work , i know i have to chance the ec but it's possible the ec do the gtx not detect in bios and in windows? i have check the voltage of the vga and it's good the die of the gpu is little hot at used
                                          04-21-2022, 10:01 AM
