LG 55LM8600 does not power up..three flashes of power light
  • damiane
    • May 2013
    • 14
    I have a LG 55LM8600 that stopped powering up after a storm. From previous experience and reference another post (link below) for the same issue, I replaced the power supply board and main board, but still no luck, same symptoms. I have not checked voltages etc. as I was ok with throwing boards at it based on the information at hand. Any other suggestions on what this could be?
    https://www.badcaps.net/forum/showth...ht=lg+55lm8600
  • russpall
    LG 39ln540v - red light flashes twice, no power to LED driver?
    by russpall
    Hi there,
    I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
    The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
    08-27-2024, 01:07 PM
  • cajoeg
    Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
    by cajoeg
    Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
    The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
    02-10-2025, 04:01 PM
  • CraigR
    Hp x360 15-u499nr power light flashes continuously.
    by CraigR
    I have an Hp x360 15-u499nr laptop with a continuous white blinking power light. The laptop does turn on. The light flashes with just the battery and if I disconnect the battery and just use the power cord it still flashes and with both connected it still does. I have updated the bios and tried a hard reset with battery unplugged and power cord unplugged and holding down the power button for 60 seconds. I can't think of what else to try.
    09-16-2024, 06:12 PM
  • dicky96
    Bang & Olufsen (HP) Omen Laptop power light flashes once but no boot
    by dicky96
    Hi guys
    I have a B&O Omen laptop here. It has very specific fault symptoms, hopefully someone can give me some guidance
    If I plug in a known good 180W third party charger the little LED next to the power jack on the laptop flashes red once, but the laptop will not start. It will not flash red again unless you unplug and reconnect the power.
    If I remove the main battery (I can't see a cmos battery) then the led by the jack does not flash when I plug in the adapter, but if I press the power on button with adapter attached it flashes once white every time...
    03-24-2023, 06:33 AM
  • PantherDave
    by PantherDave
    Hi all!
    05-29-2024, 02:01 PM
