Panasonic TH-65PX600U Solarized Picture.
  • sburdett
    • Sep 2016
    • 5
    I have a Panasonic TH-65PX600U that has an intermittent Solarization problem. consistently getting worse and worse. Other than that the tv works fine. I attached a few pictures for reference. Any help would be greatly appreciated. Also the menu is not solarized.
  • Goznu
    • Aug 2013
    • 41
    Re: Panasonic TH-65PX600U Solarized Picture.
    It kinda sounds like the T-con board. I had a similar issue with a Vizio that I had worked on. It would be fine for about 5 minutes, then I could see images but they were clearly incorrect weird blotchy images. I researched and found that there was a defective chip on that t-con board. I ordered a refurbished board from shopjimmy ( they replaced that chip with a higher quality one). It works great now. There is a reset for a problem like this, but I don't know what the codes are. If there has been some work done on this set previously, the reset may work. I would try that before diving into it.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      As its a Plasma, I would say the A board is failed. Have you images of the boards ?
      • sburdett
        • Sep 2016
        • 5
        I don't see an A board on the schematic. The boards listed are:
        These pictures show the boards and there functions:
        This is a picture of my PA board:
        I looked all over and did not see any obvious bad caps or ICs.
        Thanks for the help!
        • sburdett
          • Sep 2016
          • 5
          • sburdett
            • Sep 2016
            • 5
            After doing some more testing it turns out its only doing this on the HD inputs so now I am thinking its the DG board. Does that sound right?
            • FZG
              Panasonic AG-1000B VHS player with bad picture quality
              by FZG
              Hello!
              I recently got an old VHS player from Panasonic and just for fun I want to try to repair this device. It is an AG-1000B portable VHS player from 1990 and it has a problem with picture quality in playback mode.
              Picture in playback mode is very noisy and often loses sync but the still images are nearly perfect.
              I want to know, is this something that could be solved by recapping or is the video head likely gone?
              Also, what mechanism is this?
              Any feedback is appreciated!...
              05-06-2024, 07:16 AM
            • rumi409
              LG OLED C1 Pixel Cleaning Made Picture Worse
              by rumi409
              ​​​​​​ Hi,
              I'm trying to resurrect a LG OLED C1 TV that has some panel banding. I used the TCON error bypass to get a picture. I was able to update the firmware as well. But when I performed a pixel cleaning to try to get the banding out, it made the image significantly worse. I tried to undo the effects of the pixel cleaning by performing a factory reset and IN_Stop, but that didn't work. Any way to reset pixel cleaning data?...
              11-15-2024, 01:09 AM
            • Bazfletch3
              Panasonic TH-65FX800A backlight LED's working but picture is very dark
              by Bazfletch3
              Hi all
              While I have quite a decent background in electrical & electronic troubleshooting & repairs, this is my first time stripping down an LCD TV for repair.... I have inherited a 3yr old Panasonic LCD which has a picture, but it is quite dark (too dark to be watchable - but still quite easy to see; I didnt need a torch to see it).
              I started by checking and trying to adjust all of the picture and backlighting levels, but that made little to no difference. I also did a factory reset.
              From there I envisaged that the backlighting wasn't working, however...
              01-08-2024, 10:18 PM
            • Tr0ll
              by Tr0ll
              Original T-con:
              First replacement T-con:
              10-07-2023, 07:48 PM
            • JJAAMM
              by JJAAMM
              Problem
              07-06-2023, 06:01 AM
