Sanyo DP47460
  • hbdeals
    • Oct 2014
    • 55
    Sanyo DP47460
    Just got one of these TV's that powers up to the Sanyo splash screen then shuts down. I was told that nothing has ever been done to it, but the power supply board has 3 different brand named capacitors in it. Rubycon, Nichicon, and one green Suncon.
    I'd like to find out if these are the original caps before I go poking down the path of hacking up the audio circuit. The solder joints look factory, but if someone has replaced these with caps that were just lying around, who knows if they are even the correct values.
    There's a schematic on the web for everything except the power supply board.
    Is there anyone that knows of a way to get a schematic or component list for the power supply of this unit?
  • hbdeals
    • Oct 2014
    • 55
    Re: Sanyo DP47460
    I removed the power fail diode and the set powers up and stays on. There's no sound because the audio amplifier has no supply voltage now. Does anyone know the point where you can supply the audio circuit with an external 13 volt power supply on this model?
    Here's the manual https://www.badcaps.net/forum/attach...6&d=1370375597
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Re: Sanyo DP47460
      What diode did you remove?
      • hbdeals
        • Oct 2014
        • 55
        Re: Sanyo DP47460
        Originally posted by dick_barton
        what diode did you remove?
        d1674
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          Re: Sanyo DP47460
          This should help you
          https://www.youtube.com/watch?v=KSYCn93pz6k
          • hbdeals
            • Oct 2014
            • 55
            Re: Sanyo DP47460
            That video is a slightly different design. This board has no 13 volt test point marked on the board.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              Re: Sanyo DP47460
              Does it have the same IC?
              • hbdeals
                • Oct 2014
                • 55
                Re: Sanyo DP47460
                It does have the same audio voltage regulator, but the board is laid out differently.
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  Re: Sanyo DP47460
                  What voltage do you have between Pin2 and Pin4, also between Pin7 and Pin 4 of IC1670
                  • hbdeals
                    • Oct 2014
                    • 55
                    Re: Sanyo DP47460
                    I already buttoned it up and using the tv with a sound bar, but IC1670 was getting a 24 volt input and 1.1v output. I'll try to check those pins when there's some spare time. Thanks for your help.
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      Re: Sanyo DP47460
                      I suspect the chip is faulty as in the video and needs replacing.
                        by sam_sam_sam
                        03-31-2024, 02:12 PM
                        by sam_sam_sam
                        07-01-2024, 06:34 AM
                      • shamsudeen
                        Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                        by shamsudeen
                        Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                        I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                        i know that in linear power supply the noise will be very low comparing to SMPS supply....
                        07-19-2025, 07:14 AM
                      • JimBanville
                        Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                        by JimBanville
                        The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                        Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                        I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                        I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                        09-13-2023, 07:21 AM
