Sharp LC-42D69U Need main board help
  • kevinm34232
    • May 2012
    • 1884
    I've determined that the main board is bad, TV is dead with 5V standby going to main board.
    I have been unable to find the exact replacement for the last couple months, so I thought I'd just check some voltages on the main board.
    I do have a very similar working main board that is for a different panel, so I was able to compare voltages.
    Basically on the original board, I have 5V in and 3.3V out as seen on the regulator in the last photo, but nothing really else.
    The other board has readings at the other regulators in the area. But I'm having trouble tracing where it's breaking down..
    In my hand written mess anything in ()'s is the working board.
    Any help would be appreciated! Thanks.
  • CapLeaker
    Leaking Member
    • 8352
    Re: Sharp LC-42D69U Need main board help
    Maybe post a hi res picture with all the voltage measurements on it and the differences to the other board?
    • advant
      by advant
      02-03-2020, 12:25 AM
    • Dani_2024
      by Dani_2024
      10-28-2024, 05:06 PM
    • ygorsan
      by ygorsan
      🧩 Problem Summary:
      • I
      07-28-2025, 08:34 AM
    • jb_Bak
      by jb_Bak
      CN6401
      Pin 01 NC
      Pin 02 NC
      Pin 03 "BL_ON": 0V
      Pin 04 "N/C"
      Pin 05 "STBY 3.3V": 3.5V
      Pin 06 "GND": N/C
      Pin 07 "AC_OFF"...
      09-27-2021, 04:52 PM
    • JDC
      (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
      by JDC
      ONN 100012588
      Issue: No Power, Then Rebooting After Main Board Change
      Short answer: replace main board and power board
      Technical answer: replace main board and Q306 & Q307 on power board.
      Long answer:
      TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
      07-15-2022, 07:39 AM
