Samsung Plasma PN51D550C1F bad Xmain
  • CapLeaker
    Leaking Member
    • 8183
    I've got a bad Xmain, BN96-16523A (LJ92-01763A) to repair. I know the D series has tons of trouble and the firmware update. Only the board has been given to me to repair, not the whole TV.
    A replacement Xmain is hard to find and I need to get that one going.If I measure the diodes and IGBT's in circuit, they are almost all shorted.
    Question is with what did you guys come up with to replace the IGBT's: RJP30H1 and 30G124 at Digikey, Mouser ETC? Haven't too much luck yet.
    I think the SF10A 400V and the RF1501 ultra fast diode shouldn't be a problem to substitute.
  • CapLeaker
    Leaking Member
    • 8183
    Re: Samsung Plasma PN51D550C1F bad Xmain
    Had a bit more time:
    Q4104
    Q4101
    Q4503
    Q4202
    Q4301
    Q4302
    all shorted. The diodes are O.k.
    found them all on Ali.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Good work buddy, let us know how it goes after you replace them.
      • CapLeaker
        Leaking Member
        • 8183
        That's gonna take a while until the parts come from Ali. I hope there isn't anything else bad on that board. I am not so into these Plasma's...
        However I got a few other interesting things that I have to look at next week.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Yeah should sort it Ive had similar on them Sammys the older ones theres normally alot more that blows up but these it normally is just one fet that switches too fast and blows the other. Keep us updated anyway
          • General-lee1969
            • Jan 2016
            • 6
            • canada
            Same here. I find most IGBT's shorted. Let us know how you make out. A used x-main is like finding hens teeth!
            • CapLeaker
              Leaking Member
              • 8183
              Time will tell...
              Yeah... good luck finding a spare Xmain... I couldn't find one.
              • General-lee1969
                • Jan 2016
                • 6
                • canada
                Any luck yet with receiving and installing the components?
                • CapLeaker
                  Leaking Member
                  • 8183
                  haven't received the parts yet.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Same set here today, same issue. 6 fets toast:
                    2* RJP30H1
                    2* 30G124
                    2* 30F124
                    All shorted, cheaper to replace board than fix it and quicker too. Panels in these are junk anyway so expect panel to fail shortly after Xmain is done.
                    • Nick's Tvs
                      • Jan 2014
                      • 621
                      Came across a few of these. I highly recommend not plugging in the ribbons that lead to the panel on your X-main once you have performed the repair. A bad panel can cause that x-main to short out immediately and these panels an above average panel failure than most Samsungs I have seen. The reason you don't want to plug in X-main ribbons yet is so that you can check the output voltage of your X-main to the panel and make sure that indeed it is giving out the correct output voltage. Once you know that you have successfully repaired the board then go ahead and proceed to plug in the panel once the set has had time to discharge.
                      Like that if the board keeps blowing on you, you know its panel failure and not due to a bad/incomplete repair.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Good point I have had these slim sammy panels get line shorts causing the panel to crack or the sus boards to blow. Shame as I like the image on these.
                        • CapLeaker
                          Leaking Member
                          • 8183
                          2* RJP30H1
                          2* 30G124
                          2* 30F124
                          My Xmain doesn't have any 30F124 IGBT's in it at all. I've received today the RJP30H1's and I replaced those. Still waiting for the 30G124's
                          BTW good tip Nick, thanks! Also I do know that the panel where the Xmain came out of, is working fine.
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Well G and F 124's are basically the same fets so they probably just used what they had laying about. Also dont forget to check the Ymain over Capleaker these use combined ERC so Y can kill the X after repair.
                            • General-lee1969
                              • Jan 2016
                              • 6
                              • canada
                              I replaced the components that CapLeaker said in the above post and my tv now works! Had to get the parts from China so I had to wait a month but it worked!
                              Thanks again CapLeaker!
                              • CapLeaker
                                Leaking Member
                                • 8183
                                I am glad it worked for you! I still haven't received the 30F124's that I have ordered yet.
                                • CapLeaker
                                  Leaking Member
                                  • 8183
                                  Got my 30G124 IGBT's today. Got a working X-Main to report!
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    Sweet work bro
                                      09-07-2024, 05:50 AM
                                    • Biruslapio
                                      Samsung PL42C450 plasma X-Main IGBTs
                                      by Biruslapio
                                      Hello, the problem with this TV is it has all the Y and X voltages, but does not produce any image.
                                      It had a TON of cracked solder joints on these boards, fixed all that I could find, but in the last test I forgot to plug in the Y-SUS to control board flat cable, it was left dangling and possibly some pins shorted to the panel metal ground, the X-Main buzzed quietly then blew up in 3 seconds after powering up, annoying.
                                      Two RJH30E2 shorted, they are 360V 35A 1.7VCE IGBTs, the problem is I don't have any 360V IGBTs, only 300V or 600V, would two RJP3065 fit in? It's...
                                      04-08-2022, 01:16 PM
                                      09-06-2024, 11:40 PM
                                      09-06-2024, 08:40 PM
