LG 47LN575V suspect bad LEDS - what spec LEDS can I replace with?
+ More Options
Posts
  • Chipdeath
    • Sep 2016
    Hi all.
    My LG 47LN575V decided to die last night. Suddenly went black but sound carried on. Trying to turn off/on see a brief flash of the 'LG' logo bootup screen then back to black screen.
    TV is ~3 years old.
    The 'flashlight' test reveals the picture IS still there, so it's definitely related to the backlight, and my research indicates these are very prone to this being caused by LED failure.
    Now, I've read up and found a few videos about checking these LEDS - either by testing the whole strip with a 24V source or by checking LEDs individually with a 3V or just under source... I'm pretty confident that I can diagnose any busted LEDS, but replacement strips seem a bit hard to come by and really rather expensive (I'm in the UK).
    how feasible/sensible is it to simply swap out the damaged LEDS, and if I do what rating LED should I replace them with? if I couldn't get hold of an appropriate LED, could I get away with just soldering a resistor or something in place (and accept the not-too-great backlight civerage of course) - I've seen people saying they've successfully just soldered some wire in place to fix this where the LED has failed open, but of course that's going to hasten the demise of the remaining ones so I'd rather not do that approach.
    My level of skill? I've successfully brought various things back to life by replacing failed caps (a PC motherboard, an old LCD TV, a sky+ PVR box) so I can use a soldering iron - although I'd be the first to admit I'm no professional. I have a very very basic knowledge of electronics and own a meter so I can check continuity and voltages etc., but I can't design circuits or necessarily diagnose them beyond playing "spot the burnt bit or bulging cap".
    so... can I replace the LEDS myself, should I? and what should I replace them with?
  • flocko
    • Nov 2012
    • 1121
    • uk
    Re: LG 47LN575V suspect bad LEDS - what spec LEDS can I replace with?
    check eBay item number 252529898655 for an easy way to repair defective LEDs
    • Chipdeath
      • Sep 2016
      Well... good lord. That's an incredibly precise, to the point and helpful reply.
      I'd had a quick look on ebay for the strips, but didn't realise someone had created such a quick and easy kit.
      Thanks!
      • flocko
        • Nov 2012
        • 1121
        • uk
        I have been selling these kit all over the EU for along time.makes replacing LEDs an easy DIY repair
        • Chipdeath
          • Sep 2016
          Bought the kit, found I actually had 2 LEDs dead - one was failed open, the other closed. TV now working great again, so thanks!
          Only very minor gripe with the kit is that the supplied flying leads weren't long enough - I needed another inch or so on the negative lead to reach a suitable solder/test point (the -ve trace close enough to the LED was really thin, but a few inches along was huge). I just had to solder a bit of extra wire on, so no real problem.
          The only other issue I have is that my wife was looking forward to a new TV....
          • flocko
            • Nov 2012
            • 1121
            • uk
            Thanks for the feedback and comments, perhaps giving your wife the money you saved to spend on herself, would put things right. Turn down the back light setting in the menu,that should save you from any more LEDs failing the way of the other two
            Flocko
            • 102mm
              • Dec 2013
              • 181
              • us
              Flocko
              Flocko that is an awesome idea. I was thinking of doing the same thing, but i talked myself out of it.. I have a ton of LED strips just laying around waiting for the right TV.
              Craigslist Picks & Fixes
              2 ea - Samsung 52"
              Samsung 60"
              • flocko
                • Nov 2012
                • 1121
                • uk
                Thanks 102mm All the LEDs in my kits are new,coming from new in box sets that are transit damaged. with the rate of fail that we are seeing , and the number of different strips being fitted (makes/ Model +size) I think they fill a need in the diy market for a low cost easy repair. I will be bringing more LED types to my listing. I sell to all over the EU and in good numbers. I am sure the US would be a good market also for you
                • ivtec
                  • Dec 2008
                  • 1967
                  Hi flocko ; i have LG50ln5100 with bad L led Strip HC500DUN-VP1-11XX and a few more Bad leds,can i use any of these strips on this model? thanks
                  http://www.ebay.com/itm/Heesung-HC39...3D361634180928
                  • martino
                    Not so "senior"
                    • Aug 2013
                    • 997
                    • canada
                    How do you get to buy tv's like that? I've been trying to land myself something like that here in Canada.
                    Proud owner of dozens of broken TV's and many,many,many boards.
                    Our website and passion:http://hollenhundshepherds.com/
                    • grahamv53
                      • Sep 2020
                      • uk
                      Hi, sorry to say but I can't find Flocko on ebay or the web, any help much appreciated
                      Graham thanks
                      • unimatrix93
                        Which resistor should I remove/replace to decrease current to backlight leds?
                        by unimatrix93
                        Dear community, I want to increase the lifespan of my backlight led in my TV by decreasing the current.
                        However I need some help identifying the resistor I need to replace to achieve this.
                        Thank you!
                        11-29-2024, 05:05 AM
                      • Pipolups
                        Corsair K70 LUX RGB dying LEDs
                        by Pipolups
                        Hi there !
                        I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                        Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                        10-08-2024, 11:58 AM
                      • tmhobadcap
                        Samsung un65h6203af led replacement question
                        by tmhobadcap
                        This tv is with sound but no picture. When light shines on the screen, we can see the image. This is a typical backlight problem. I opened it and found quite a lot of the leds are damaged. But the damaged ones are all shorted. No one is open. Is there a special reason? (From my past experience, both can be happened)
                        When I supply 3V to each of the good leds, the currents range from 105mA to 154mA. From these figures, I think the leds are 3V and about 0.5W. I plan to replace all the damaged leds only (because the price of the led strips is very expensive), but I could not find 3V 0.5W...
                        10-03-2023, 11:37 PM
                      • THE GTC
                        Insignia NS-37D20SNA14 intermittent LEDs
                        by THE GTC
                        So I use this TV daily as a second monitor for my PC or my Playstation - at one point a few months back I tried to fix the problem - but in the process, I figured out something that works so I haven't posted this for awhile. It is an annoying trick to have to do though, so I decided to post about it to see if anyone could spot what's wrong. It baffles me because it works on it's own half the time.
                        When I first got this TV, I was told it wouldn't turn on, and of course I did the flashlight test, and the image was there. Also, the red LED on the front indicated that it had power (it...
                        11-03-2020, 02:40 AM
                      • lmcancu
                        RCA RLDED 4331B: 43 inch LED TV: Backlight issue
                        by lmcancu
                        Hi I am having an issue with the LED backlight of this TV. I can see the picture with a flash light, so I determined it was a backlight issue.
                        Initially, after opening it I found 2 shorted and 1 open LED on 2 strips (total of 4). I removed the LEDs and shorted the pads together to verify if the backlight would work.
                        Testing it, I found the backlight turned on and I measured 54V when TV was in standby (off), and 100v when TV was turned on. The 4 strips each contain 9 LEDs, so 36 in all minus 3.
                        Instead of putting it back together I decided to replace...
                        04-01-2023, 01:11 PM
