Panny 65VT30 Screen Power Cycle Issue
  • jaxsully
    • Sep 2016
    • 3
    New to the forums here and searched for an answer extensively before posting.
    I have a 2011 Panny 65VT30 and it has run flawlessly for 5 years. The other day it started to click and what seemed to be a power cycle and then came back on. During this time I heard the typical 'clicking' noises that it does when it turns off and on.
    This happens when the TV has been on for an extended period, i.e. over 3 hours.It will cycle and then it might not happen for another 20 minutes.
    I know many have reported the 7,8 & 10 red light blinking issue. However, the light does not blink on mine.
    Any thoughts?
    Sully
  • tw2005
    • Oct 2011
    • 6458
    Re: Panny 65VT30 Screen Power Cycle Issue
    Sounds heat related could be A board but just to share my experience with my 50st30 which also has gremlins. Mine if left on in standby for extended periods does 1 of 2 things. Waking it with the remote it will either click and the tv is dead and no standby led , or the led blinks goes to start and then suddenly click power dies no led light. Using the power switch if I cycle it the standby comes back and i can turn it on normally.
    I thought it was going to be A board but I recently found another board and no changes so it is looking like the P Board.
    • jaxsully
      • Sep 2016
      • 3
      So are the boards getting harder to find? Is there a good source that you can share?
      • tw2005
        • Oct 2011
        • 6458
        Always gets hard with time. Pts electronics refurb a lot of stuff. Otherwise shopjimmy Payless components ebay etc
        • lambchopsnz
          • Jul 2016
          • 63
          • New Zealand
          Can you still open shopjimmys website because I've tried several times and I just get an error saying your not authorized to access this server... or similar to that anyway any ideas?
          • Nick's Tvs
            • Jan 2014
            • 621
            If you are told you can not access this server it is because you are not located in the USA. If your IP address is not within the USA they won't allow you to access the website. They only service within the USA and I think Canada as well.
            Lastly, take a look at the back side of your SS board and more specifically the large capacitors on it. I just had that model come into the shop a few weeks ago with similar problem, and all those caps had cracked solder joints. To be honest, you should probably flip over your SC and power supply board as well and check all three for cracked solder joints just to be safe.
            • Moreno83
              • Jun 2014
              • 2008
              • The Netherlands
              And when you have the back removed , also replace the screws!
              • Mgiffune
                by Mgiffune
                06-09-2024, 10:28 AM
              • justice171
                Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
                by justice171
                I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
                Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
                1. Verified that all critical voltages are present:
                  • 3.3V and 5V are always present if DC is plugged.
                  • 1.8V on the BIOS chip is present.
                2. Checked the power button functionality:
                  • When pressed, the voltage drops to 0V, indicating the button is functional.
                3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
                  • Confirmed connectivity is intact, ruling out issues
                11-26-2024, 12:39 AM
              • claws77
                lenovo flex 5 14itl05 power sequence issue
                by claws77
                hi guys, my motherboard will not start no matter what
                when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
                but rest nothing happens no sign of life.
                this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
                with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
                but now nothing happens no matter how much i wait/ charge/ press and hold power button.
                i have no knowledge of motherboards ....
                10-20-2024, 02:48 PM
              • yaya3gmax
                Laptop Power Issue – Works on Battery, Fails on Adapter Load
                by yaya3gmax
                Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
                Symptoms:
                • Laptop works normally on a pre-charged battery.
                • Battery does not charge when adapter is connected.
                • Without battery:
                  • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
                  • Speakers “pop” when power cut occurs indicating harsh sutdown.
                  • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
                08-21-2025, 07:16 AM
