TCP60ST50 7 blibking red lights
  • JSJohn
    • Aug 2016
    • 60
    Re: TCP60ST50 7 blibking red lights
    Thanks!!! I definitely owe you several
    Of course, I trusted ya. Your advice made perfect sense regarding the wrong diagnosis with a bad board.
    I have put the cover back on with 4 screws as you suggested. Gotta protect those new boards. HA HA HA!
    Placing a order for the new screws and will definitely take care while installing them.
    Thanks again. I hope someone learns from my pitfalls. I look forward to contributing and gaining more insights.
      ME Firmware Cleaning Guide
      by SMDFlea
      Here`s a quick ME Firmware cleaning guide.
      The guide is basic,its main goal is to show you how to use intel FIT,its highly recommended that you all follow the guide posted at win-raid
      (The attached FIT version is 11, if your ME Firmware (FW) is not 11.0.*.* follow the win-raid guide. Use the tools version for your ME FW, for example: ME System Tools v9.1 For systems running ME v9.0 - v9.1)
      A video,software (intel FIT) and practice bios are all included. I`ll post a better video and more advanced guide at a later date.
      1. Open the...
      09-09-2020, 09:10 AM
    • Francesc V.
      Christmas lights - Something I am doing wrong
      by Francesc V.
      Hi:
      i am trying to repair this Christmas lights from my parents. They are incandescent lights, no led lights.
      I have tried with 12V a 24V small lights that I found in Aliexpress but is obvious that are not the right ones. They last microseconds connected. Do they blow because of Amps or Volts?
      If I measure the Amps in the string........it's only 90mA. If I measure the Volts in the "green box"......it's between 0 and 190V, but doing a little bit of maths from the number of bulbs in series.......it's only about 6V per lamp.
      Could...
      03-11-2023, 07:38 AM
    • ktmmotocross
      ps5 bv, schem or repair guide
      by ktmmotocross
      Have this PS5 EDM-033 with one beep. error is some short but i dont find one on main rails. need schem or guide to check all rails
      I would like to have BV, schem or repair guide so add them here
      07-02-2025, 11:57 PM
    • bialag
      Lenovo ThinkPad E14 Gen 5 - Not Powering On - 3 Blinking Lights - 20 volts 0.224 amps
      by bialag
      I have a Lenovo here that does not want to power on. The motherboard appears to be clean, no sign of corrosion or obvious fried components. When plugged in, I see 3 blinking lights and then off. It would cycle the 3 blinking lights every 10 seconds or so as long as I have the adapter plugged in. Amp meter shows 20 volts, 0.224 amps, no fan spin, red light indicator near the charge port.
      Thermal camera shows a section of the motherboard that is warmer than the rest. It is near the connector labels JRTC1 (CMOS battery). Diode measurement to ground for pin 1 = OL,...
      03-25-2025, 05:56 PM
    • acedogblast
      by acedogblast
      11-02-2024, 05:13 PM
