sharp LC-40E67UN death set no stand-by
  • hmendez86
    • Jun 2015
    • 344
    • united states
    No power at all. No 5v on the power supply,,,fuse are good and rectifier good.....transistor are good too....
    Re: sharp LC-40E67UN death set no stand-by
    Pictures, pictures, pictures.
    • hmendez86
      • Jun 2015
      • 344
      • united states
        Sharp RDENCA354WJQZ (DPS-208BPA) Power Supply Unit.
        http://www.shopjimmy.com/sharp-rdenc...wer-supply.htm
        OK, SJ does not have the pictures of the bottom side of the board, please take good straight shot pictures of the bottom side of the board so I can give you the test point to test.
        History of the TV?
        I can see some fusible resistors (Low Ohm white ceramic body resistor) on the board.
        • R_J
          • 9624
          Its hard to tell from the picture but I think the area I outlined may be the standby circuit, What is the number on the ic I outlined in yellow? it may be one of those TNYxxx ic's, they like to go bad.
          • hmendez86
            • Jun 2015
            • 344
            • united states
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              This looks very similar
              http://jestineyong.com/samsung-lcd-tv-repair/
                Hate to say this, but that jestineyoung info is wrong about that 2.2 Ohm resistor, it is not for the Source pin of the STBY SMPS IC7905, if you look at the IC spec and the application circuit, you do want to put the resistor on that Source pin.
                If he traced out the board, he would have seen that R7918 (2.2 Ohms) is connected to D7918 which is the rectifier for the AUX winding of the SMPS transformer to produce the DC filtered by cap C7915. So check that to see if it is open or not.
                There is a fusible resistor R7914 that feed the main B+ for running the STBY IC7905.
                BTW, I wish the bottom side picture is a straight shot and no glare but was enough to see how the STBY SMPS IC is connected.
                It looks like someone did some works on the board, some of the solder joints do not look good.
                • CapLeaker
                  Leaking Member
                  • 8352
                  Did you check if the output on the secondary of the STBY voltage pin is shorted?
                  If there is no shorts there, than the problem has to be on the primary side. Usually either the resistor that budm is talking about is bad or the rectifier diode with it's filter cap. The STBY IC can fail too...
                  Yep, looks like someone was already working on that board.
                  • hmendez86
                    • Jun 2015
                    • 344
                    • united states
                    I had luck i just replace the 5v stanby IC7905 and it work fine.....thanks for help well keep for records..
                    • CapLeaker
                      Leaking Member
                      • 8352
                      Very good! Sometimes the PWM (IC7905) fails, not usually, but it does. Thanks for the update!
                      • neilc6
                        • Nov 2015
                        • 1550
                        I have the same TV and replaced a blown TNY264PN but still have no standby voltage. R7918 measures 2.4 ohms and I can't find R7914. Will keep looking. All diodes and the single transitor test ok in that area of the board. Main filter cap measures 165VDC which is low.
                        • dskall
                          • Oct 2016
                          • 2905
                          • usa
                          165v is not low for standby
                          • neilc6
                            • Nov 2015
                            • 1550
                            Ok found R7914. It is under the bottom shield and measures open. 2.2 ohm 1/2W? Marked W1/2J 95K.
                            Found this thread for finding a replacement https://www.badcaps.net/forum/showthread.php?t=36749
                            This thread applies as well https://www.badcaps.net/forum/showthread.php?t=24435
                            Shopjimmy repair kit (RDENCA336WJQZ) replaces IC7905 , D7908, R7914, and 7918
                            • Yanleb
                              UN65MU6300FXZC, no standby LED but power supply good. Bad IC1604 25Q40?
                              by Yanleb
                              My UN65MU6300FXZC is dead and the standby LED stays off. The power supply is good. The main board is BN94-12434A.
                              Disconnecting the main board from the power supply makes the backlight come ON.
                              I did disconnect the panel cables and the WIFI modules, the board is still dead.
                              I did read in many posts that IC1604 25Q40 becomes corrupted. It has proper 3.3 volt on VCC pin 8. I did read that if I post its dump here someone can fix it. Is that right?
                              Thanks.
                              11-18-2024, 12:34 AM
                            • SJX1290
                              Sharp 50BL2AE stays on standby
                              by SJX1290
                              Hi,have Sharp 50BL2AE which is not powering, stays on stand by, White control led is permanently on, signal from remote is coming on board as well from power -mutifunctional button on back side. All power voltages seems to be ok. Backlight checked, working..
                              Any ideas?
                              12-10-2024, 01:17 AM
                            • pigmeaki
                              JVC LT-55k800 (A) No standby light with good PSU
                              by pigmeaki
                              TV:JVC LT-55k800 (A)
                              MB: 17MB230 (260319r2)
                              PSU: 17IPS72
                              Hello! I got a lt-55k800(A) to repair and I am having trouble figuring out if I can save the motherboard or not. Almost 100% the problem is the mb since I have another psu and it does exactly the same. The problem. I was told the tv looked completely dead and indeed there isn't no standby light working. The psu (17ips72) has all the correct voltages in the connector to the mb when it is not connected. Meaning 12v 24v (for sound). There is no stby 5v but it is created by the mb. When I connect it to the main board...
                              11-10-2024, 05:26 AM
                            • Tecc1229
                              Sharp LC- 58Q620U - Standby Light, No Backlights or Image
                              by Tecc1229
                              Hello, I have a Sharp LC- 58Q620U 58" LED 4K TV.
                              When you initially plug the TV into the 120V outlet, I get the initial standby red LED light. After you press the power button the red LED goes out and no other lights come. There is no backlight flash, nor image on screen. No audio with HDMI source plugged in, nor does my laptop detect another monitor plugged in. T-con board makes a clicking sound with or without LVDS cables hookup or off.
                              My first thought was that it had a faulty PSU. Reading voltages, I was getting a swinging voltages from the DC output from the...
                              09-17-2021, 10:50 AM
                            • tvguy12012012120
                              by tvguy12012012120
                              02-07-2025, 05:13 PM
