862D+ hot air station.
  • Malachi
    • Dec 2015
    • 1077
    • Usa
    I just purchased this, since I'm a novice, I thought it might be good enough.
    Has anyone here used one?
    http://www.ebay.com/itm/122048804047...%3AMEBIDX%3AIT
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: 862D+ hot air station.
    Looks fine matey same as any other soldering or hot air station. Glad to see your investing in some good equipment
      Please let us know how well its made on how well it holds up.
      I wonder what the Wattage of the soldering iron is, it only shows total Wattage.
      • Malachi
        • Dec 2015
        • 1077
        • Usa
        I already have a decent iron. I will probably only use if my hakko clone breaks.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          Must say about half the price of the one I bought without the soldering iron, which I did not need.
          As ReeceyBurger123 says should work fine. Just don't have the airflow set too high which will blow your smd resistors/caps off the board if you are not careful.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            +1 also the temperature for hot air even on multilayer boards does not need to be set over 360 degrees if any higher it will warp/burn the board.
            • zeon22
              • Aug 2016
              nice price I think that I will try to find one for sale in the UK
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                I actually use a Maplin 40w soldering iron which are £7 on ebay and some cheap 858d hot air station which is abiut £25 so works out cheaper.
                Ive had both for about a year or two not an issue and Im able to preform chip level repairs with no lifted pads not about the equipment if you ask me but about your skill.
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  +1 Agree. It is advisable to practice on redundant boards. Different packages require different amount of heat and time to remove successfully without lifting pads.
                  Edit
                  I also find Kapton tape useful to help sheild the heat from parts which are very close to the part you are removing and is cheap to buy off Ebay
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Yep Im able to unsolder and resolder caps on dual layer board with just a soldering iron just keep pads heated and slide old one out and new in with out lifting pads. Its hard to get used of the techniques but over time you will get it.
                    Also with K tape you have to be careful as if its not down properly and your using hot air it can pull up iff the board and lift parts with it I learnt that the hard way once.
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      Thanks. Hasn't happened to me....yet, but I'll be keeping a careful eye out now that you've mentioned it.
                      • Malachi
                        • Dec 2015
                        • 1077
                        • Usa
                        I just ordered some kapton tape, 5mm and 10mm.
                        I assume when pulling it off, wait till things have cooled off for a while? Don't want to pull the component off with the tape?
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          That's correct or you could pull off components. Let things cool right down and then remove.
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            You couldn't be any more correct mate
                            • Malachi
                              • Dec 2015
                              • 1077
                              • Usa
                              Not sure if I want to attempt repairing a faulty tnpa5335 though. If I don't get it right most places on eBay refuse to work on boards if they've been worked on before and these boards are almost impossible to find.
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                If you don't try you'll never gain the expertise.
                                https://www.youtube.com/watch?v=w3IzrKcun8s
                                • Malachi
                                  • Dec 2015
                                  • 1077
                                  • Usa
                                  True but if I was a begginer at a body shop, the owner would probably prefer I work on the Chevy than the Ferrari whose parts are expensive and hard to find.
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    In my experience I have found that people who have an interest can pick up skills extremely fast. Years ago we employed two youngster to give them a taste of electronics. Within weeks one of them could etch and build a circuit board far better than I could and I had been doing it for years.
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      But your not at a body shop, your working on a Tv board, even if you rip a pad most of the time you can just reconnect it simply. At least give it a go.
                                      • diif
                                        • Feb 2014
                                        • 6978
                                        • England
                                        Nope, the garage owner gave me the apprentice, the Porsche to fix whilst he played with some clag on a dog turd coloured Nova saloon.
                                        • liquidzorch
                                          862D+ solder station iron out of control when fan on
                                          by liquidzorch
                                          Hello.
                                          I have a soldering station, 862D+, and every time the hot air gun is on, even if it is just cooling off, the soldering iron controller stops controlling. Let me explain what has happened so far, as it took a while to get to this.
                                          First, the switch that turns on the hot air gun started to fail, the light came on, but temp never rose, I would have to switch it multiple time to get the gun to start heating, this was due to the contact inside being carbonized. I opened the switch up, clean the contacts, and it would work fin for a while until carbonized again. So, I ordered a switch...
                                          06-09-2022, 08:49 PM
                                          HP Station de travail Z2 format tour G4 i7-8700 Specification for Upgrade or Repair
                                          This specification for the HP Station de travail Z2 format tour G4 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Station de travail Z2 format tour G4 boardview and Station de travail Z2 format tour G4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          09-12-2024, 02:20 PM
                                          MSI Gaming GF66 11UG-820FR Katana Dragon Station Notebook GF Specification for Upgrade or Repair
                                          This specification for the MSI Gaming GF66 11UG-820FR Katana Dragon Station Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GF66 11UG-820FR Katana Dragon Station boardview and GF66 11UG-820FR Katana Dragon Station schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                          09-07-2024, 05:20 AM
                                          HP EliteBook 840 G6 + UltraSlim Docking Station Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 840 G6 + UltraSlim Docking Station Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + UltraSlim Docking Station boardview and 840 G6 + UltraSlim Docking Station schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                          09-06-2024, 06:00 PM
                                          09-06-2024, 12:30 PM
