Lg 60pg60fua occasional black horizontal line
  • braxton
    • Nov 2009
    • 146
    I picked up this 2008 60" plasma. It has an occasional black horizontal line that briefly appears on the top half of the screen and then goes away. I pulled off the back and found that when I gently press on one of the heatsinks on the upper Y buffer board i can make the black bar appear. If I either press down gently or lift up gently on the heatsink, the black bar appears. When I release, the black bar goes away.
    So I have a bad connection or short on one of the chips on the upper buffer board I suspect. It is very hard to find this part online, especially since I am from Canada.
    Could a heatgun repair this? Oven reflow? Any suggestions?
    Thanks.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Lg 60pg60fua occasional black horizontal line
    Reseat buffer connections going to the PDP.
    • braxton
      • Nov 2009
      • 146
      I did try re-seating all ribbon cables and the connectors to the YSUS main but no change. Maybe I will clean the connections with isopropyl alcohol and try again. Pressing on the middle IC chips reproducibly cause the black bar to appear so I think it is a chip connection issue. I might need to remove the thick glue strip holding the chip/heatsink assembly in place -for a closer look...
      • braxton
        • Nov 2009
        • 146
        Oven reflow seems to have done the trick, time to put it through its paces...
        • braxton
          • Nov 2009
          • 146
          Worked fine for about 4 hours and then horizontal strip started acted up again due to heat.
          The heatsink over the chips is sealed by a rubbery compound that I'm not sure how to remove.
          Also seems next to impossible to find an upper buffer board for sale.
          Does anyone have a spare part EBR38574601???
          • rstrube
            ViewSonic Pf815 (branded as P225f) Horizontal Deflection Issues - Running out of Ideas
            by rstrube
            Note: apologies I initially posted this request for help in the wrong forum! I am reposting it here and will take down the original posting.
            Hi Everyone,
            I've been working on repairing this beautiful CRT monitor off and on for the past several months and I'm really at a loss for what might be causing the problem.
            Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video)....
            Yesterday, 01:37 PM
          • rstrube
            by rstrube
            Hi Everyone,
            Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video). The monitor itself is branded as a P225f, but it turns out that it's actually a Pf815 that has an Add-On smallish PCB that expands it to support...
            Yesterday, 12:19 PM
          • Ihandyrepair
            Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
            by Ihandyrepair
            Hi guys
            I just started fixing 4k TV few months ago. so I am still learning a lot
            I got this tv from friend complaint is ghosting or horizontal lines on image.
            never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
            then it started to show the ghosting white image.
            I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
            it has 3 thin small boards at the bottom of the...
            12-05-2022, 04:18 PM
          • cubytus
            Samsung UN50TU8000FXZC shows thin horizontal green line when warm
            by cubytus
            Hi to all,
            I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
            I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
            Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
            01-10-2024, 01:26 AM
          • kca
            by kca
            Hello all ~
            08-31-2025, 06:38 AM
