Samsung PN50B450B1D - Thin Colourful Vertical Lines
  • tgs.fish
    • Aug 2016
    • 3
    Make: Samsung
    Type: Plasma
    Model: PN50B450B1D
    Pictures: http://m.imgur.com/a/wG0rf
    I have multicolored thin vertical lines that appear on all inputs, over the menu and test screen. I have tried to clean the ribbons, updating the firmware and resetting the picture.
    I have replace the bad capacitor that is in the second and third picture and it has stopped the 2-3 clicks.
    Anyone have any advice or tips on where to start?
    Cheers,
    Tom
  • martino
    Not so "senior"
    • Aug 2013
    • 997
    • canada
    Re: Samsung PN50B450B1D - Thin Colourful Vertical Lines
    you can try cleaning the ribbon cables at the logic board,but I'm afraid this is a bad panel.
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
    • tgs.fish
      • Aug 2016
      • 3
      Thanks for the answer, It did not work..
      Cheers,
      Tom
      • martino
        Not so "senior"
        • Aug 2013
        • 997
        • canada
        sorry to hear that.
        You know all boards are good so you could make some money back by selling them.
        • Falki
          Colorful LCD Vertical Lines on Samsung ue55es8090
          by Falki
          Hello there, ive recently found an older 55inch Samsung SmartTV.
          A similar issue has been posted as well but also with no actual response ...
          08-12-2025, 04:19 AM
        • Stanley1843
          by Stanley1843
          06-29-2024, 11:54 AM
        • pni
          LG 49uf695v vertical coloured lines
          by pni
          Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
          11-14-2025, 03:15 AM
        • x_orange90_x
          Samsung UN46C8000XFXZA vertical bars/horizontal lines
          by x_orange90_x
          I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
          The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
          09-04-2023, 12:09 PM
        • polaro
          Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
          by polaro
          Greetings,
          I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
          08-27-2022, 08:46 AM
