Sony KLV-32V300A
  • aanan
    • Dec 2010
    • 222
    • India
    Sony KLV-32V300A
    hi
    Sony KLV-32V300A dead .
    power led 5 sec on off st by led 2 time blinks.
  • PantherDave
    by PantherDave
    Hi all!
    05-29-2024, 02:01 PM
  • Andreas_de
    Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
    by Andreas_de
    Hello!
    i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
    Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
    Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
    04-12-2025, 10:38 AM
    03-31-2024, 02:12 PM
  • Exim
    ASRock N100M, no picture no boot, but semi-alive
    by Exim
    Hi guys,
    I managed to semi-kill an ASRock N100M board after updating Bios from 1.10 to 2.01. It's a zombie now, dead, but not dead.
    ASRock N100M special features:
    - CPU soldered to board, small Intel 12th gen
    - iGPU
    - four POST LEDs
    Problem after updating Bios to 2.01 using the in-Bios update tool: no picture, no boot.
    I am not sure anymore if it booted at least once successfully after updating the bios to 2.01, maybe not, I can't remember. I think it did not.
    Symptoms:
    - no picture/signal on any of the display connectors,...
    04-01-2025, 02:36 PM
  • thstuff
    Sony OLED XR-77A80J - Initially dead, now 4 Flashes
    by thstuff
    A) TV initially dead
    B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
    C) Was able to perform a Reset from Settings menu and completed out of box configuration.
    D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
    E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical...
    12-26-2024, 09:10 PM
