LG 50PK350 Clicking
  • sordids999
    • May 2013
    • 2161
    LG 50PK350 Clicking
    Hi guys
    just picked up this tv constant clicking so i straight away tried test patterns all good so reflowed the main BGA IC100 and all working again
    testing tv now
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: LG 50PK350 Clicking
    More XD engine Cpu failures fucking junk from Lg they are. Thanks for the thread mate
    • Sisko
      Onkyo-593 No power and now clicking sound
      by Sisko
      Hi all!!
      Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
      10-03-2025, 02:18 PM
    • slimmy182
      [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
      by slimmy182
      Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
      I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
      Looking on google I found this:...
      01-14-2023, 11:55 AM
    • beetle1303
      Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
      by beetle1303
      I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
      On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
      01-13-2025, 08:49 PM
    • mikelu53
      Samsung UN60D8000YF Clicking BN44-0432A
      by mikelu53
      I have a UN60D8000YF with a BN44-0432A power supply and a BN41-01622C main board.
      The set was working then not,then started clicking.
      Wilth the power supply disconnected from the main board I can occasionally get it to power the LED back lights , getting it to stop clicking is luck.
      Checked caps and diodes and mosfets the best I could. When it stop clicking there is 5v and 18v on the connector to the main board.
      A schematic or suggestion would be great.
      01-21-2023, 03:14 PM
    • B0r1s
      Samsung UE49KS7000SXXH - fast clicking sound in standby mode
      by B0r1s
      PSU - BN44-00878A
      Symptoms:
      The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
      A weak clicking sound was coming from the transformer.
      Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
      Progress:
      After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
      01-17-2023, 04:58 PM
