Lg 50pt350
  • Jtroutt19
    • Aug 2011
    • 164
    Lg 50pt350
    Hey guys so here is what i got going on. When plugged in you hear a click then the backlight comes on for about a second then shuts off with another click. You can then hit the power button again and the process repeats itself. Where do i start in diagnosing. No swollen caps on any of the boards. Any help is appreciated. Thanks!!
  • sordids999
    • May 2013
    • 2161
    • uk
    Re: Lg 50pt350
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • sordids999
      • May 2013
      • 2161
      • uk
      Re: Lg 50pt350
      also this: https://www.badcaps.net/forum/search...archid=6766904
      • Jtroutt19
        • Aug 2011
        • 164
        Re: Lg 50pt350
        Originally posted by sordids999
        Ran the test where you jumper the wires. And the tv cycled through the test screens just fine. Main board it is...?
        • Sharpa
          Repair attempt Philips 55OLED804/12
          by Sharpa
          I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
          The symptoms when bought: Philips logo appears then tv turns off
          Things tried so far:
          1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
          2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
          Yesterday, 08:30 AM
        • huzo
          HP Omen shuts down when loading OS
          by huzo
          The model is 15ec-1061nm
          Board number is DAG3EDMB8D0​
          SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
          10-29-2024, 12:05 AM
        • Giggle2562
          Lenovo V15-IIL motherboard swap (in V15-IKB) shuts down when internal display is connected
          by Giggle2562
          I have a Lenovo V15-IKB that had a damaged motherboard. I replaced it with a motherboard from a Lenovo V15-IIL.
          The board powers on, but it shuts down after about 10-15 seconds. This only happens when the internal display (LCD panel) is connected.
          Here's what I've tried so far:
          • When the internal display is disconnected, the laptop works perfectly fine via HDMI.
          • The laptop shows an image on the internal display for a few seconds before it shuts down.
          • I tried swapping the LCD panel with a known good one.
          • I tried swapping the LCD cable
          11-06-2025, 12:36 PM
        • riko 656
          Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
          by riko 656
          I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
          Laptop Model:
          • Model: Lenovo Legion Slim 5 16APH8
          • GPU: NVIDIA GeForce RTX 4070
          • Main BIOS chip size: 32MB
          • VBIOS chip size: 16MB
          Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
          What I Have Tried So Far:
          1. I
          11-04-2025, 05:14 AM
        • brav1ez
          ASUS FX505GD shuts off after POST — no BIOS, power button unresponsive
          by brav1ez
          I have an ASUS TUF Gaming FX505GD that's powering on, showing the ASUS logo for about 2 seconds with keyboard backlight, then immediately shuts off. After it shuts down, the power button does nothing until I unplug the laptop completely. No fans spin afterward either.
          I’ve tried:
          - CMOS reset
          - Removing the SSD/HDD
          - Reseating RAM (removing each stick individually stops boot completely)
          - Cleaning up recently applied thermal paste around CPU/GPU and nearby VRM components (issue persists)
          With...
          09-07-2025, 10:47 AM
