LG 50PB560B PLASMA loses pic after 15 mins
  • Fleckers tv
    Fleckers TV
    • Nov 2015
    • 89
    • uk
    This Plasma will lose its pic after 10 -15 mins , but s switch off and on and its back for another 10.....
    However If I take the back of and run it .... no problems it has stayed on for 4 hours now, as soon as I put the back on , give it 10 and its off.
    so a heat problem, but where , Main board BGA ? Sus boards ?
    as its a Plasma spraying freeze is unlikely to ignite the screen again , so just wondered if anyone has seen anything like this
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: LG 50PB560B PLASMA loses pic after 15 mins
    it panel fault blow up glass crack every whyrer fire bomb call police
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Haha just messing bud, this the one that had lose screws ? Also got images of the boards ? What does Vs do when the image goes out ?
      • Fleckers tv
        Fleckers TV
        • Nov 2015
        • 89
        • uk
        Not sure on VS cos to make it go off I have to keep back screwed on, I will do a check later.
        yes it was the loose screw one, which I thought I had sorted but as soon as I put all back screws in it went off after 10 mins
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Start heating the boards then mate, set it to a full white screen too on max birghtness (uses max power-set heats up faster) use a hair drier for it.
          • Fleckers tv
            Fleckers TV
            • Nov 2015
            • 89
            • uk
            the weird thing is the tv is now on, propped up in my workshop with the boards against the window on the hottest day of the year and the picture stays on, and its bloody hot, as soon as the back is screwed on it lasts 15 mins
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              Drape a sheet across the back of the set with the cover removed. Allows air through but keeps the heat in and see if it still shuts off.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Good idea matey, I might start using that method.
                • Andrew F. Ali
                  • Jan 2014
                  • 2450
                  • Trinidad & Tobago
                  Can't figure out how draping a sheet over the back would keep the heat in but allow air. If air is allowed in then that will cool the heated air and cause some sort of convectional flow or circulation, which would keep the set cool. If you say cover the back with the sheet to keep the heat in and prevent cooler air from entering, I'll go for that....
                  • matyka
                    • Jan 2015
                    • 179
                    • Uk
                    Hello, I have the same problem here.
                    Any idea?
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      That's exactly what I am saying. Fold up a sheet or use some thick material to act as a back panel to block heat loss from inside of the set. The method works and I have been doing it for years.
                      • Snoopyx98
                        • Feb 2020
                        Hi can you explain me how to put e sheet in back of the panel
                        • Nick's Tvs
                          • Jan 2014
                          • 621
                          I have seen cracked solder joints on the Y-sustain board, the Z-sustain and the power supply. I highly recommend you do a visual check on all three boards and reflow any suspicious joints. If you don't see any obvious cracked joints, then I recommend you remove the main board from circuit, run the color pattern test with the back cover on and see if you can get the color pattern test to run for longer period of time than with the main board connected. If that is the case then most likely the issue is with the main board. If the TV set still fails after that 10 minute period then you may want to double check those cracked joints again.
                            Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                            This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                            I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                            I am comparing them to a brand new one that I installed
                            The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                            I going to let it run for several days before I remount back on the wall next to the...
                            09-05-2024, 06:48 PM
                          • berriferous
                            Samsung PN43E450A1FXZA (Plasma) - Display up for 4 mins, then shuts itself down
                            by berriferous
                            Set was manufactured in 2012. I'm trying to diagnose where the problem is. I am assuming it is over-currenting after heating up? Display looks fine until it decides to shutdown. If I keep turning it on, it will eventually refuse to power up and requires unplugging to get it to respond again.
                            I originally thought there would be some easily detected bad electrolytic capacitors, but I don't see the telltale signs. There might be some very minimal bulging on one of the x buffer board. BN96-22092A (LJ92-01852A).
                            If I unplug the power feed to the X/Y board (LJ92-01854B), the...
                            12-16-2024, 09:58 AM
                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                            This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                            09-12-2024, 02:30 PM
                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                            HP ProBook 450 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                            This specification for the HP ProBook 450 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + APC Back-UPS 700VA boardview and 450 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                            09-06-2024, 08:10 PM
