Vestel VES315WNDB-02 firmware needed
  • 6ot4hr
    • Oct 2014
    • 87
    • Croatia
    Hi, i have Končar TV 32'' set with 15 standby led blinks, no picture and no backlight shows up. PSU-17IPS11 and MB-18MB82S, are the models of the boards inside.
    I have read that most times it is needed to reflash flash memory, but cant find the roms anywhere. Voltages on STBY seem okay 12V, 2.4V, 5V and inverter goes to 99V when set is powered.
    Tried the "freeze" trick using canned air on flashroms but set didn't boot
    Anyone seen problems like this?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Vestel VES315WNDB-02 firmware needed
    Hello are you sure theres no picture on the Lcd ? Switch the Tv on and use a torch to see if theres an image but no backlight. Normally failed firmware on this will only cause the set to be flashing the standby Led nothing else.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Watch this video can help test the set, sounds to me like you have a failed Led in the screen not the firmware:
      https://m.youtube.com/watch?v=RxwdC7V5Ue0
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        +1 as ReeceyBurger123 said, even with a torch it can be difficult to see an image on the screen if not light source is not bright enough.
        • 6ot4hr
          • Oct 2014
          • 87
          • Croatia
          Exactly, tried the Torch test but couldn't see any picture, well off to panel disasembly and leds checkup.
          Will inform you what happens
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Awesomeness keep us updated
            • 6ot4hr
              • Oct 2014
              • 87
              • Croatia
              Marking this as solved, found two burned LEDs, thanks ReeceyBurger for your help!
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Awesome work glad to help How you going to go about replacing them ?
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Also watch my 17mb82 flashing Led repair video I advise you follow that video and do the same steps on this Tv as shown in the video its also on my channel.
                  • 6ot4hr
                    • Oct 2014
                    • 87
                    • Croatia
                    Will probably scrap few good LEDs from broken screen TV that i have layin around, hope they match
                    Willl surely watch your video you suggested, thanks!
                    • nikgegr
                      • Aug 2017
                      • greece
                      f and u fl20891 firmware update core needit main vestel 19MB82S
                      • Daniel Larsson
                        Firmware file for LG SK10Y Soundbar stuck in Please wait loop needed
                        by Daniel Larsson
                        My LG Soundbar, SK10Y, has somehow ended up in an endless "PLEASE WAIT" loop and I am now starting to suspect that the firmware is causing this, and I can't manage to connect via the app to push a new firmware in as it never really starts.
                        I can trick it to start via HDMI ARC and it actually starts up, flashes OPTICAL and then goes to ARC where the sound (including sub) is perfect, but the white led indicator keeps blinking and after 20 seconds it says "GOOD BYE" and shuts down.
                        During these seconds the function button is not working...
                        08-13-2025, 10:29 AM
                      • massimomax
                        Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
                        by massimomax
                        Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
                        spero che qualcuno può averlo per riprogrammare eprom. grazie
                        Post in English !!!
                        I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
                        02-28-2025, 07:27 AM
                      • anlu
                        Vestel Firmware - Toshiba 32W133DN
                        by anlu
                        Hello, i have an old Toshiba 32W1333DN (sorry, misspelled the headline) TV that had the standby led green/red flashing and no lightup problem, i repaired it by measure the led output as suspect led problem, i measured the LED:s one by one and found one bad led, i replaced the the led-straps and the TV works.
                        Now i need to update the software because the new rc "RM-L890" does not work and i think maybe it could be an firmware issue?, i have struggled to find it without any success because all of the links where invalid, i contacted Toshiba but they do not support this model...
                        02-04-2023, 12:59 AM
                      • comptek
                        Vestel 17mb110p Firmware Needed
                        by comptek
                        Hi guys this Tv is just flashing
                        I believe it's the firmware crashed wondering if there is a core update or something available
                        Gary...
                        02-09-2023, 05:26 AM
                      • EduCabral
                        [Help Needed] Yatour YT-M06 (Pioneer 1) – Firmware or Schematic Request
                        by EduCabral
                        I'm currently working on reviving a Yatour YT-M06 CD Changer Emulator module for use with a Pioneer 1 interface (specifically with a DEH-P5950IB head unit).
                        While the unit is recognized as a CD changer, none of the USB, SD, or AUX features respond, which leads me to believe the firmware may be corrupted or incompatible.
                        🔧 Details:
                        • Model: YT-M06
                        • Interface: Pioneer 1
                        • MCU: Fujitsu MB89F202
                        • Goal: Find a valid .bin firmware file or memory dump from a working unit
                        I'm happy to attempt flashing, analyzing memory dumps, or doing hardware-level...
                        07-15-2025, 12:26 AM
