Samsung un32j5205
  • johns1mj
    • May 2015
    • 242
    Samsung un32j5205
    I have a 32" Samsung that will not turn on. I have power. The power button will light and flash like every other samsung when it starts. I do not have back lights or a tone when the tv starts. The power supply it built into the main board. When powered on the digital audio out lights up. There are two blue led lights on the t-con board. If all hooked up both lights stay on steady. If either lower cable to the screen is unhooked only the top light lights up. I have unhooked both lower cables, the cable to the t-con and unplugged the led lights and still no power on chime. I believe this is a bad program on the main board. Testing showed these voltages on the pin outs.
    cyb5_out .566 v
    y 51.7 v
    pb 51.7 v
    pr 0 v
    gnd 0 v
    loop back_enable 3.321 v
    5v 4.92 v
    test_sr1 0
    test_sl1 0
    Top to bottom of the led power supply pins
    14.04
    .674
    .672
    3.96
    I could not find any similar tvs to mine listed in the forums.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Samsung un32j5205
    You have a failed Led in the Lcd screen, would you like a link to the video on how to test them ?
    • johns1mj
      • May 2015
      • 242
      If i have a failed led would disconnecting them bypass them allowing the tv to start or does the circuit need to be complete?
      • CapLeaker
        Leaking Member
        • 8070
        the circuit needs to be complete. The LED's are strung like a X-Mas light chain. One goes out, the whole string goes out. So you have to take the panel apart and find the bad LED and replace it.
        • johns1mj
          • May 2015
          • 242
          used two batteries for 2.5 volts. tested all 21 leds. they all lit up.
          • johns1mj
            • May 2015
            • 242
            Sorry 14 led two strips
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Hmm wait there let me re-read this as sort of confusing.
              • flocko
                • Nov 2012
                • 1121
                Were did you get this set? as UN = Samsung supplied to US market? can only find BN94-08470B main board from USA ?
                • johns1mj
                  • May 2015
                  • 242
                  ok, lets start at the beginning. The tv power light will flash 6 times, I believe this is standard for samsung. I have no startup chime or display.
                  • johns1mj
                    • May 2015
                    • 242
                    yes they are like $20 on ebay. That is the correct board for my tv.
                    • flocko
                      • Nov 2012
                      • 1121
                      These are common faults with this set in the US,Main board replacement needed and not available in UK. we are just starting to see models failing with this type one board does every thing setup over here.
                      • johns1mj
                        • May 2015
                        • 242
                        ok, I will try one. Do you need one?
                        • johns1mj
                          • May 2015
                          • 242
                          Solved!!
                          Check your power supply. Mine was only putting out 14v. The TV needs 19v to run. I replaced the power cord and all problems were solved.
                            09-07-2024, 05:50 AM
                            09-06-2024, 11:40 PM
                            09-06-2024, 08:40 PM
                            Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                            This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-06-2024, 06:20 PM
