LG 42LV5400 powers on, no video, no sound
  • Sevenqi
    • Jul 2011
    • 292
    Re: LG 42LV5400 powers on, no video, no sound
    I had the same model and same problem, what I did was to reflow the main processor on the main board with heat gun, problem fixed.
    • drkthundr
      • Feb 2016
      • 45
      I will look into that.
      • Dgtech
        E. Technician
        • Apr 2009
        • 1462
        • Steeler
        I'm dealing with the same issue here https://www.badcaps.net/forum/showth...ighlight=Ic602
        Its great to see that my reading are very similar to other people. I'm stuck on why that Ic602 is not doing its job. I'm not sure though.
        • drkthundr
          • Feb 2016
          • 45
          I have been wondering that as well.
          • Dgtech
            E. Technician
            • Apr 2009
            • 1462
            • Steeler
            I sold mine today (55 inch - LG 55LV5400) in non working state for $100. Lets keep the money moving - no time to stop.
            • drkthundr
              • Feb 2016
              • 45
              I'm going to keep at for a while longer. I like a challenge.
              • ScottKnight
                • Mar 2017
                Joined because of this thread since I have a 55LV5400 that is doing exactly the same thing. I have been through everything drkthundr and dgtech have as well as two trips through the oven. Possible for that IC602 to go bad?
                • Dgtech
                  E. Technician
                  • Apr 2009
                  • 1462
                  • Steeler
                  #28
                  Check the thread here for both the service manual and the training manual PDF's.
                  https://www.badcaps.net/forum/showth...636#post737636
                  I think the mainboard needs replaced as others have done to fix the problem.
                  • Dgtech
                    E. Technician
                    • Apr 2009
                    • 1462
                    • Steeler
                    #29
                    I tried to look up the datasheet for that IC602 to try to see what turns that pin 10 off but I got nowhere with it. After reading mostly all of the posts in several threads on this set, I'm convinced that if the board can't be reflowed by heatgun or oven method, just replace the mainboard.
                    Search for the EAX or EBR or EBT # on your mainboard. I saw one this morning going for 127 from canada.
                    • drkthundr
                      • Feb 2016
                      • 45
                      I touched up q504 and the corresponding resistors around it, Plus i put foil tape around and on the backside of the board for Ic101. I squeezed some no clean flux around and under the IC and took my hot air desoldering device to it and heated it up and let it cool down. Removed foil tape and put the board back in and tv turned on. Success but discovered the screen has lines in it caused by the screen. They are fine lines but they are there, so cant sell that way. NNNNooooooo Guess i will be parting this one out and selling boards on ebay. sometimes you win some some, times you loose some, and sometimes you have to take what you get and move on.
                      • mrjiffy6
                        As well as many others, I fixed this problem by reflowing the whole board in a oven and it's been working perfectly since then.
                        When I prepared the board for reflowing, I noticed a small curve on the heatsink so it wouldn't even touch the main IC, making the heatsink completely useless. So before mounting it back, I flattened the heatsink surface and put some thermal paste where the IC sits on.
                        My guess is indeed the BGA solder balls of the main IC cracked slowly through thermal cycling, which seems to be a well known problem of the BGA ball packages of ICs. It might also explains the slow degradation of the TV performances until it wouldn't even "boot" at all.
                        • minho_newt
                          • May 2016
                          Yep, I will vouch for the main board reflow. My LG 42LV5400 had no picture/no sound, the PS was good, all caps okay (even though I changed two of them anyway).
                          In the end, I put the board in the oven at 385-395F for ~12 minutes. Reconnected everything and BAM...the darn TV works again. I don't know if this is a long term fix, probably not, as you are still stuck with that crappy lead-free solder. The perfect solution would be to do a proper reball with leaded solder of the main IC.
                          • mrjiffy6
                            Well, guess what? It is not a long term fix
                            The picture started to look crappy again about 3 months ago. I'm waiting until it "dies" again to reflow it once more!
                            • neilc6
                              • Nov 2015
                              • 1550
                              If you search the main board part number on ebay, you will find some sellers that do reballing for around $100 USD.
                              • Mendykremodel
                                • Oct 2018
                                Hi, i have an lg 50pk750. Im experiencing the same thing. The tv turns on, the main blue light is reactive to remote and manual button pushes, but no menu/vol bar, no sound and no picture. The lcd screen is lit and looks normal, even lights up for a moment on start up. I replaced what looked like a bad capacitor on the power supply board with no change. After reading the thread, im thinking the problem is somewhere on the main board instead. Am i correct? Thanks in advance
                                • soeren
                                  A2442 - No sound over internal speakers and no video playback
                                  by soeren
                                  I am facing a strange issue, I don't have any sound over my internal MacBook speakers and also the video won't start. If I change to my head speaker or via HDMI (speaker on my external Display) the sound works over the head speaker or Display and also the video starts (ex. youtube).
                                  All happened after the battery ran out of power overall several days when I was on vacation.
                                  I tried to remove the battery and then reconnected the battery, and then the MacBook Pro 14 2021 won't accept any power from my power socket. Then I removed one speaker, connected again the battery...
                                  07-26-2024, 01:24 AM
                                • JRade
                                  Audio video receiver KENWood KR-V990D,no sound
                                  by JRade
                                  When I select the FM receiver, I find a radio station, the sound is heard on REC OUT(L,R), REC TAPE1(L,R),REC TAPE2(L,R) on high-ohm headphones, the sound regulation does not work.
                                  The output reacts when I connect the record player to PRE OUT FRONT L, the sound is heard in the speaker but the sound regulation does not work. Then it does not matter what I chose on the front selector.
                                  I replaced the capacitor C303/0.047F, nothing changes.
                                  I'm asking for help, what should I do next?
                                  Thanks in advance!...
                                  08-05-2025, 10:23 PM
                                • FrancescoV
                                  Onkyo HT-R390 no sound output, video output ok
                                  by FrancescoV
                                  Good morning everyone,
                                  I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                                  The firmware reported is the following:
                                  M:1.00/11107BLP
                                  D:?.??/????????
                                  O:1.00/11107AL
                                  The DSP firmware given the question marks seems corrupt.
                                  On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                                  05-11-2025, 02:59 AM
                                  HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                                  This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                                  09-12-2024, 02:00 PM
                                • JaquesPratt
                                  Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                                  by JaquesPratt
                                  I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                                  This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                                  07-16-2024, 01:04 AM
