LG 60PA6500 no picture
  • anisski
    • Jul 2016
    Hello;
    I have an LG 60PA6500 with no picture but it does have sound. I have read many posts here that helped me with some troubleshooting but now I am stuck.
    The voltages going to the Y-sus and Z-sus boards match what they should be.
    I had read that if you remove the top Y buffer and get a picture on the bottom half then the panel may be shot so I tried that.
    When I remove the top Y buffer I get colored lines on the bottom half of the screen.
    When I remove the bottom Y buffer I get colored lines on the top half of the screen. If I get lines there then the panel is not shot, is that right?
    If both buffer boards are in I get no video at all but there is sound if I am connected to my aerial.
    I have replaced the Y sus and Z sus boards. I also replaced the main board as it has had a bad HDMI port since shortly after our house was hit by lightning about a year ago.
    Any suggestions? I would really appreciate the help!
  • JJAAMM
    by JJAAMM
    Problem
    07-06-2023, 06:01 AM
  • noisykid
    Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
    by noisykid
    5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
    12-30-2024, 07:15 PM
  • srs
    Insignia NS-50DR620NA18 w/ large vertical lines & no picture
    by srs
    I'm not sure what to do next and came here since y'all helped me fix a 50" plasma TV back in 2014, which is still working!
    A friend gave me an Insignia NS-50DR620NA18 50" TV that suddenly developed large vertical lines on it. He said he had no idea what might have caused it and has replaced it with a larger TV. He was going to throw it away.
    I did not notice any bulged or leaking caps on any board, the voltages produced by the power supply match the voltage that the pins are marked. The backlight leds are working. I have tried cleaning the ribbon cables...
    04-22-2023, 02:40 PM
  • Fly_Among_Stars
    VIZIO E70-E3 Half picture with half TCON
    by Fly_Among_Stars
    I have a VIZIO E70-E3.
    Symptoms: Black screen, no picture, but LED backlights are working.
    I probed the power board and voltages are as listed on the board.
    Main board appears fine, too.
    I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
    There are two separate ribbon cables feeding the LCD.
    If both are connected, the screen is black.
    If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
    04-24-2023, 08:20 PM
  • gavric
    Vizio M70-C3 Half picture is bad, main board on its last leg?
    by gavric
    Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
    When tv powers on vizio V logo shows nice on whole screen. picture 1
    When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
    When i start youtube picture shows on left side fine, right is all scrambled. pic 2
    When i click video to start playing picture goes black(like when you change...
    09-02-2021, 08:55 PM
