Panasonic THP54V20a
  • chrismurphy
    • May 2014
    • 251
    • australia
    Panasonic THP54V20a
    Does anyone know the correct Vsus voltage for this TV
    currently running at 200v should it be maybe 209
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic THP54V20a
    any particular reason it needs adjusting? Very rare to have to adjust anything.
    Reported 194V but my 50" is about 203V. where are you getting the 209V from?
    To my knowledge they're preset and there is a Low and High adjustment in the service menus.
    https://www.badcaps.net/forum/showth...ight=tc-p54g20
    • Buzztv
      Panasonic TC-P42S60 Plasma,how to check Vsus
      by Buzztv
      This is my first post in attempting to keep my beloved 2013 Panasonic plasma tv going.
      About 6 weeks ago the tv was turned on but then immediately shut off. There was no recent power surge or popping noise or any other symptom.
      I checked all of the obvious things and decided to try a replacement power supply board (PSS in Panasonic lingo).
      I would like to check the Vsus but this is one of the final models and at that point Panasonic did not indicate the Vsus and Vad voltages inside the chassis. It looks like they were discouraging people from making adjustments....
      10-27-2019, 01:24 PM
    • Andre Gilbert
      by Andre Gilbert
      11-20-2024, 08:52 PM
    • AquaMan Ua
      Problem with PANASONIC CF53 laptop after changing BIOS settings
      by AquaMan Ua
      Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
      05-17-2025, 09:40 AM
    • aa10aa10
      Panasonic Toughbook CF-33 mk1 BIOS repair
      by aa10aa10
      Good day,
      I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
      I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
      01-21-2025, 06:13 AM
    • ItepK
      Panasonic TX-P42G30E green light blinking, no video, no audio
      by ItepK
      Hey everyone!
      I've gotten this TV for free, neither have it seen a TV repair man, neither have it been opened before.
      This post describes my entire troubleshooting process of this TV.
      When I turn it on using the ON/OFF switch at the side of the TV, the light rapidly flashes green, then it stays on, but it does not react to any of the remote buttons, side buttons, and doesn't play audio.
      I've taken the unit apart, and I've started to check some voltages:
      • On the P11 connector, there is 15V DC only for a brief moment, then it goes
      12-22-2023, 05:06 AM
