Lg plasma 42s1
  • hispeck
    • Aug 2015
    • 258
    • nigeria
    Lg plasma 42s1
    Hey Guys, i have LG 42s1 am working on right now, the 197v and 65v vs and va volt comes up when i power the plasma without plugging ysus and zsus, but when i plug them the two voltage will shut down
    please can anyone help with a solution on how to troubleshoot it?
    Hispeck
  • alfredomfr1
    TV Plasma LG 60PN5000 ZSUS 15v missing
    by alfredomfr1
    All Voltages are OK except ZSUS 15v.
    YSUS board disconnected still 15v missing.
    ZSUS was replaced: 15v missing.
    Any help will be appreciated...
    04-29-2022, 11:26 AM
  • reessi
    LG Plasma ZSUS Flashing Screen, No Booting! - 50PB690V
    by reessi
    Replaced Zsus beginning of year as most transistors were short stopping tv powering up.
    Now screen flashes on off continually and ZSUS ticks. Looking like replacement maybe faulty or could something else cause it to shut down.
    If I remove both tabs from ZSUS to screen but keep all other connectors to ZSUS on then TV boots properly but screen very dark without ZSUS output, no ticking from ZSUS. So it only shuts down when under load from screen.
    If it is ZSUS then how to fault find, I already looked for shorts. No transistors shorted or caps and its...
    12-13-2017, 01:18 PM
  • Salvatore057
    plasma TV Lg 42w451 - why is the zsus igbts damaged when the ysus is plugged?
    by Salvatore057
    I am trying to fix my plasma TV which is not powering on due to damaged IGBTs. I have changed two igbts and 2 IC drivers on the zsus and also two igbts on the ysus.
    Now everytime I plugged the ZSUS and the YSUS boards to the power board, the two 30f124 IGBT on the ZSUS are damaged and the TV stays in standby mode. When I plug the ZSUS board alone the TV turns ON but I do not see pictures. When I plug the ZSUS board without the two 30f124 IGBTs and the YSUS board, the TV powers on with a picture.
    I am lost, should I change the YSUS board? Is the YSUS board damaging...
    04-29-2018, 01:29 PM
  • ArMaaN376
    Samsung PS51E550 Plasma TV
    by ArMaaN376
    I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
    Opened TV cover & observed foll
    a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
    b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
    c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
    How to confirm Y -Buffer board...
    06-19-2024, 04:05 AM
  • jm1234
    Panasonic plasma TX-P42ST50 - 6 blinks
    by jm1234
    anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
    It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
    I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
    I checked that board for any obvious faults...
    05-22-2024, 06:59 AM
