Kdl-46s4100
+ More Options
Posts
  • xZapx
    • Jun 2016
    • 12
    Re: Kdl-46s4100
    The contacts on the ribbons look OK. I should also note that I went back and pulled the one ribbon so I get 50% display and selected an input source, proceeded to input audio, and I get sound out of the TV too.
    • xZapx
      • Jun 2016
      • 12
      Re: Kdl-46s4100
      Was re-reading the thread because I am trying to get back to further testing. I'm game to check the T-CON board voltages with and without the one ribbon plugged in. However, I don't see test points that specifically call out these voltage sources. Is there a board diagram or list of the test point locations/names I should reference? I didn't see anything in the service manual.
      Thanks!
      • ivtec
        • Dec 2008
        • 1967
        Re: Kdl-46s4100
        Thanks!
        This TV is famous for Bad Panel,i have same model# myself that i was able to repair it by replacing FP1 Fuse on T-con now it has a good pic and sound but ended up with a Vertical line,i have all good boards and a bad panel,if you have a good panel which i doubt,i can sell you the Main board and T-con board for cheap.
        https://www.badcaps.net/forum/attach...5&d=1457019976
        https://www.badcaps.net/forum/showth...ony+kdl46s4100
        • xZapx
          • Jun 2016
          • 12
          Re: Kdl-46s4100
          Re: the T-CON board - I know that the A board one has to be very specific to get the correct part number for the serial number range. Can anyone inform me as to how this works for the T-CON?
          FS_HBC2LV2.4 is on the silkscreen and K2204G8B0CJK by the bar code. Is anything past the K2204 significant in looking for a replacement board that is compatible?
          • steves7839
            • Nov 2014
            • 200
            Re: Kdl-46s4100
            Shopjimmy dot com has guides for how to select the correct replacement or substitute.
            • xZapx
              • Jun 2016
              • 12
              Re: Kdl-46s4100
              I had ordered a replacement T-CON board that arrived, at which point I ended up with the same functionality as the original one that was installed in the unit. The seller refunded my money, so I'm not sure if the board was ever tested or not.
              Regardless, I'm guessing this increases the diagnosis of a defective panel? If that's the case I suppose I could part everything else out since I know the A board and power board are functional.
              • dick_barton
                • Aug 2015
                • 6642
                • Wales
                #27
                Re: Kdl-46s4100
                Normally when you remove one of the ribbon cables to the panel you have half a picture and when you remove the second ribbon (after reconnecting the first ribbon) you should still have half a picture on the opposite side of the screen.
                • rollerclp
                  MSI Cyborg 15 A13VE - BIOS request
                  by rollerclp
                  Hi guys,
                  I have this MSI with black screen and keyboard backlight Can't find any hardware faults so I'm guessing the BIOS may be corrupted.
                  S/N:K2309N0039300...
                  04-15-2025, 10:21 PM
                • mostachio
                  Looking for help diagnosing a 65" Panasonic Viera TV - TH-65DX700Z (Turns on - Clicks - Turns off)
                  by mostachio
                  Hi Badcaps,
                  I've had a friend discard a TH-65DX700Z Pansonic Viera Television and I've decided to have a go at repairing it. If possible could I please get some advice in terms of diagnosing the problem so I can purchase the appropriate parts for repair whether it be components, a repair kit or a replacement board. I am happy to post pictures if required.
                  TV Details:
                  Model # - TH-65DX700Z
                  Symptoms:
                  The television turns on and displays a picture then makes a clicking sound and turns off.
                  I haven't opened it up yet but...
                  09-04-2024, 02:32 AM
                • s_henya
                  Lenovo Yoga 500-15ISK several faults
                  by s_henya
                  Hi guys,
                  Anyone ever worked on this board before?
                  Few issues im trying to resolve:
                  1. Laptop will not power up without main battery connected (missing 3.3v line)- measuring on the 3.3v coil i can see 0v but for split second it jumps to 3.3v and drops again.
                  Is this laptop supposed to power on only with battery connected?
                  2. Battery voltage + line is getting 19v, for my experience 7.4v battery isn't meant to be charged with main line voltage- is this normal?
                  3. No display on laptop screen, if i disconnect the LVDC cable and connects...
                  05-27-2024, 02:50 PM
                • Cornboats
                  Samsung 32 LE32B450C4WXXU changes source on its own
                  by Cornboats
                  Samsung 32 LE32B450C4WXXU, manufactured 2009
                  This set changes source without being asked. Turn the set on and tv channel comes on for up to 20mins then set changes to ext1 for a couple of secs then PC for a couple of secs then back to tv for the same same. Then the cycle starts again. I turned on today and there were no channels saved so I had to rescan.
                  I'm guessing the faults on the main board so have included a photo.
                  Any thoughts or ideas would be welcome....
                  12-09-2022, 10:54 AM
                • reessi
                  Acer Chromebook CB3-431, N16P1 - Multiple Hardware Faults, also Schematic Please?
                  by reessi
                  History:
                  Arrived no power, was told screen flickering for months then died.
                  Found LCD cable shredded, shorting 3.3v LCD line and possibly 13v Backlight line may have shorted to 3.3v as multiple things fried. It is my understanding that if you shorted the 3.3v line then the 3.3v regulator would shut down.
                  I found main fuse blown so I think 13v line was shorted, the 3.3v regulator had a dead short from it's 13v input to ground so now 13v line and 3.3v line on motherboard are shorted to ground.
                  Also high side switch for 3.3v LCD line was...
                  10-08-2020, 10:44 AM
