Panasonic TC-P55GT50 12 Blinking lights?
  • Diah
    • Feb 2013
    • 6437
    Re: Panasonic TC-P55GT50 12 Blinking lights?
    Dear tw2005.. here you are the snapshot
    • tw2005
      • Oct 2011
      • 6458
      yes, that is all I've ever seen. Still not understanding your point about having to clear codes. Nothing there says you have to clear anything
      • Diah
        • Feb 2013
        • 6437
        its procedure of repair to clear error code after repair the faults, i don't know where are the problem.. if you ignore this step after repairing.. its up to you.
        • martino
          Not so "senior"
          • Aug 2013
          • 997
          • canada
          you need to reset ( Clear ) the error code at service menu, other wise will not working as usual,
          pppsssttt,TW2005,(whisper voice) "You can't fix stupid"
          Proud owner of dozens of broken TV's and many,many,many boards.
          Our website and passion:http://hollenhundshepherds.com/
          • tw2005
            • Oct 2011
            • 6458
            Fair enough. No I don't worry about it and it's never been an issue for me.
            I guess if you do a self check which I think restores back to factory you'd want to save the settings first on a SD card so they can be restored for the customer.
            • Freeflynick
              • Jun 2016
              • 8
              So I tried to get into the service menu yesterday but found that once it popped up I could not navigate the lists. The remote or TV buttons did nothing - what am I missing?
              • tw2005
                • Oct 2011
                • 6458
                Did you read the information. Use numbers 1 , 2 , 3 , 4 ok , etc
                • Andre Gilbert
                  by Andre Gilbert
                  Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                  Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                  11-20-2024, 08:52 PM
                • bialag
                  Lenovo ThinkPad E14 Gen 5 - Not Powering On - 3 Blinking Lights - 20 volts 0.224 amps
                  by bialag
                  I have a Lenovo here that does not want to power on. The motherboard appears to be clean, no sign of corrosion or obvious fried components. When plugged in, I see 3 blinking lights and then off. It would cycle the 3 blinking lights every 10 seconds or so as long as I have the adapter plugged in. Amp meter shows 20 volts, 0.224 amps, no fan spin, red light indicator near the charge port.
                  Thermal camera shows a section of the motherboard that is warmer than the rest. It is near the connector labels JRTC1 (CMOS battery). Diode measurement to ground for pin 1 = OL,...
                  03-25-2025, 05:56 PM
                • Audeze
                  Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                  by Audeze
                  I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                  Does...
                  10-06-2024, 08:54 PM
                • jm1234
                  Panasonic plasma TX-P42ST50 - 6 blinks
                  by jm1234
                  anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                  It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                  I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                  I checked that board for any obvious faults...
                  05-22-2024, 06:59 AM
                • riparo
                  Panasonic Oled 55EZ950E, no picture, red led blinking every 4 sec
                  by riparo
                  Hi everyone, I have a Panasonic OLED TV model 55EZ950E, as soon as I turn it on I don't have any image the LED goes from green to red LED blinking every 4 sec, I found the service manual suggests checking OLED PANEL, PB BOARD, T-CON connectors but it seems like everything ok, I didn't find any burns under the pb board
                  I attach a link to download the service manual, thank you for anyone who can help me
                  https://tel-spb.ru/download/?brand=P...0E_LA73.rar​
                  01-11-2024, 12:35 PM
